ᐅ Bathroom layout: Is the size of the walk-in shower with a T-shaped wall acceptable?
Created on: 11 Jan 2017 23:18
muttley
muttley
11 Jan 2017 23:18
our planning is slowly approaching the final stage, and doubts are coming up about whether the shower, as currently planned, is large enough, or if we might end up flooding the entire bathroom while showering.
Please take a look at the floor plan and let me know if the shower side wall is sufficient for "average users."
Thank you very much!
Benextra12 Jan 2017 00:04
...yes, that will definitely be sufficient! A few splashes will, of course, be visible on the left as well.
I would build the side wall and install a window there. That way, you can place the shower tray, and the shower area will appear significantly larger.
Of course, as always, the water supply, slope, and drain must be properly aligned. )
Good luck
Heiko
lastdrop12 Jan 2017 09:17
I would recommend making the upper part of the wall between the shower and the toilet out of glass; otherwise, the shower area will become quite dark...
Curly
12 Jan 2017 09:22
Will the shower back wall be only 11.5 cm (4.5 inches) thick?
Sabine
muttley
12 Jan 2017 14:57
@Badjunge: Do you really think that's enough? Don't you think we'll end up flooding the bathroom?
@lastdrop: The wall won't go all the way up; it will stop at about 2 meters (6.5 feet) high...
@Curly: Yes, it will...
77.willo12 Jan 2017 18:05
I find the bathroom quite narrow and dark and would avoid the T-shaped layout.
