ᐅ Bathroom design 3.51m x 3.51m – Ideas and inspiration
Created on: 28 Jan 2015 20:22
Jochen104
Jochen10428 Jan 2015 20:22
I am looking for a good solution for our main bathroom. We have been planning with a T-layout, but I’m no longer sure if this is the best option.
Attached you’ll find the planned T-layout and an alternative.
Room details:
  • Dimensions: 3.51 m x 3.51 m (11.5 ft x 11.5 ft)
  • Door: must be on the left wall, position still flexible
  • Window at the bottom: width 2.01 m (6.6 ft), height 0.885 m (2.9 ft), sill height 1.18 m (3.9 ft), single-leaf, tilt-only
  • Window on the right: width 0.76 m (2.5 ft), height 1.20 m (3.9 ft), sill height 0.865 m (2.8 ft), not mandatory but I think it’s good for ventilation
Contents:
  • walk-in, level-access shower
  • toilet
  • bathtub
  • washbasin, width 1.30 m (4.3 ft)
  • cabinet, width 0.70 m (2.3 ft)
  • towel radiator
Unfortunately, the bathroom planner was not very creative. Do you have any good ideas?
Edit: No sloped ceilings, all walls full room height.
Bautraum201528 Jan 2015 21:26
I think this T-configuration is a good solution. The space is used efficiently and zoned well, in my opinion. I might consider swapping the toilet and shower so that the toilet is closer to the fresh air (window).
28 Jan 2015 22:28
Bautraum2015 schrieb:
I think this T-layout is good. The space is used optimally and zoned well from my point of view. I might consider swapping the toilet and shower so that the toilet is closer to the "fresh air" (window)
... and you can also look outside then – it won’t be so boring that way
Jochen10429 Jan 2015 07:45
Good morning, thank you for your feedback.
We had considered that as well. However, it was more important to me that when ventilating, the moisture from the shower is effectively removed to prevent mold from developing on the grout over time. I was personally a bit concerned about ventilating “around the corner.” What are your thoughts on this?
The partition walls are also not intended to be full height. Do you have any experience with that (2m (6.5 ft)?)?
RFR29 Jan 2015 08:05
We solved it with a 2.20 m (7 ft 3 in) high partition wall between the sink and the shower. However, we have a 1.30 m (4 ft 3 in) wide sink, not a small one as shown in the drawing.
The exhaust vent for the mechanical ventilation with heat recovery is located next to the bathtub in the service wall (bottom left in the picture). We have had no issues with moisture in the bathroom or shower.
2D Badezimmer Grundriss mit Badewanne Waschbecken Toilette und Tür
Bautraum201529 Jan 2015 09:28
Do you have underfloor heating? I wouldn’t worry too much about moisture in that case. Also, the T-wall is not built up to the ceiling, so water vapor can escape at the top.
