ᐅ Bathroom Heating and Heat Pump
Created on: 16 Dec 2016 21:19
reeneex
Good evening,
We have the opportunity to get two towel radiators from Schulte for a low price, but we are unsure if they will work with our planned heat pump. Both models operate with hot water and have a thermostat connection.
1.77 m (5 ft 10 in) long and 77 cm (30 in) wide. No. 1 for the main bathroom, No. 2 for the guest bathroom.
Should we go for it or are they useless?
seth048721 Dec 2016 15:34
During the construction meeting for the main bathroom, we were also asked whether we wanted an electric heating element in the towel radiator or to connect it to the underfloor heating. We decided to go with the underfloor heating option, even though we knew it wouldn’t provide much heating power. Our general contractor had already informed us about this beforehand.
In the WC, I would probably choose only electric heating. The shower there is likely to be used less frequently than the one in the main bathroom. Therefore, the electric towel radiator probably won’t be in use very often.
Mycraft21 Dec 2016 16:12
HERR_bau schrieb:
Because of course, heating with pure electric heaters is still more expensive than with an air-to-water heat pump... even though both run on electricity :-)
not really...
seth0487 schrieb:
We decided on the underfloor heating option, even though we knew it wouldn't really provide much heating power. Our general contractor told us the same beforehand.
As Basti already pointed out, this approach brings absolutely zero added value but costs about 500 euros upfront...
Why not save that money or install a towel radiator with an electric cartridge instead?
Bieber0815
21 Dec 2016 16:53
BastianB schrieb:
With the temperatures required for underfloor heating, you really can’t warm anything up using a towel radiator.
I understand that, but what exactly doesn’t work is unclear (bathroom too cold could be one answer; also: towels too cold ;-) ).
Mycraft schrieb:
Why not just save the money
This is probably a good idea; so don’t install a towel radiator at all. Instead, opt for a proper towel rail. For us, it’s too late now ...
seth048721 Dec 2016 23:23
Bieber0815 schrieb:
I understand that, but it’s unclear exactly what doesn’t work (bathroom too cold could be one answer; also: towels too cold ;-) ).
That is probably a good idea; so, not installing a towel radiator at all. Instead, better to have a proper towel rack. For us, it’s too late now...
In our case, the towel radiator (connected to the underfloor heating circuit) was included. Otherwise, I probably wouldn’t have installed one. An electric cartridge would have been an extra charge, although I don’t know how much. I plan to discuss this topic again with our plumbing specialist when the time comes.
merlin83
21 Dec 2016 23:47
toxicmolotow schrieb:
Attach it to the back of the washbasin, turn it on, take a shower, and then stand with your buttocks in front of it while shaving.
....and then burn your butt as your weight increases 😀
