ᐅ Basement Waterproofing / Drainage for Clay Soil and Brick Foundations
Created on: 1 May 2021 12:05
Rainer23
Rainer23
1 May 2021 12:05
Good day and a happy May 1st!
We have a problem with hydrostatic water pressure (groundwater); one basement room was literally flooded because of it. Moisture passed through the masonry. Now we want to stay "dry" in the future and are planning insulation/waterproofing of the basement exterior wall. For this, large amounts of digging were done, and it turned out that it is the clay soil that stores and releases the water.
Red brick wall above wet foundation, construction wood and pipes lying on the ground.
The facts are:
We have already cleaned and plastered the wall and brick foundation (two bricks stacked) multiple times with mortar and bitumen. After that, Styrofoam insulation boards were adhered to the wall. Now, the drainage system is still missing.
Measuring rod vertical against pink wall, green construction foil, damp spots; drainage.
And now my question:
The exposed lower two bricks (serving as the foundation) that also lie beneath a layer of clay—should these simply be backfilled and compacted with soil/sand? Because a gap has formed there due to the adhesion of the Styrofoam boards. (see sketch)
Crumbly wall with green insulation strip; red marking frame highlighting free space at the bottom.
Sketch of a wall with Styrofoam insulation, basement floor, brick foundation, cavity for drainage.
Or what would be the best/next step regarding preparation for drainage?
See sketch and photos.
I would be very grateful for helpful tips and answers...
Kind regards
Rainer
hanghaus2000
1 May 2021 12:23
The clay soil does not retain water. It prevents water from draining downward.
Install a drainage pipe at the lowest point, connect the drainage to the sewer system, and cover the wall with a dimpled membrane. Then surround the drainage area with gravel. Cover the gravel with geotextile fabric (alternatively, you can completely wrap the gravel with a non-woven fabric), then backfill with a water-permeable material.
Rainer23
1 May 2021 12:44
Thanks in advance for a response.
But regarding my previous question again:
What is the recommended procedure for the cavity in terms of structural stability and drainage? Should it be filled with sand/gravel? Or should Styrofoam be applied to create a drainage channel?
Hand-drawn construction sketch: brick foundation, clay soil, Styrofoam wall, basement floor slab, drainage note.
i_b_n_a_n1 May 2021 19:50
First clarify whether and where you are allowed to connect the drainage, or if you are concerned about "stirring up a hornet’s nest."
Nida35a1 May 2021 20:32
Be careful when connecting the drainage to the sewer system. It is prohibited. The basement floor level often requires a lifting station/pump. When many people do this, even with downspouts, basements tend to flood due to backflow.
HausiKlausi1 May 2021 23:30
How does it look from below? The best external waterproofing is useless if water then finds the next shortest path and penetrates through the ground. Even if you can manage this with drainage around the house, there might still be groundwater pressing against it from below. I know this isn’t a solution, but since I have similar conditions, I just wanted to temper expectations regarding the newly installed insulation.
