ᐅ Tiling a Basement – What Should You Consider?
Created on: 20 Oct 2022 16:47
däumchen11
däumchen11
20 Oct 2022 16:47
In our basement, one room has just a screed floor. I would like to tile the floor—not because it’s necessary, but because I want to practice tiling.
There is no heating in the room, and there should be no pipes or cables embedded in the floor itself.
Do you see any issues with tiling the floor? For example, could it affect breathability, cause mold risk, or anything else? I would assume there are no problems, but better safe than sorry. 🙂
Thanks and best regards
SaniererNRW123
20 Oct 2022 18:15
däumchen11 schrieb:
Do you see any problems with tiling the floor? Like, for example, that it might trap moisture and cause mold issues or anything else? I would guess there aren’t any problems, but better safe than sorry 😉
The only problem I see is if you mess it up 😉. Otherwise, it’s absolutely doable without any issues.
Get yourself a tile leveling system (just look it up), a good adhesive, and then enjoy the process.
P.S. I just checked my floor—it’s completely lifeless whether or not it has tiles and doesn’t breathe at all 😎:p
Prager91
7 Dec 2022 11:23
Can I fully load tiles that have not yet been grouted (after the adhesive has completely dried)?
I am about to tile my second room (laundry room) and would like to place the washing machine on the freshly laid tiles halfway through the installation due to limited space, before everything is grouted together.
Does anyone have experience with this? Is there anything I should consider?
motorradsilke
7 Dec 2022 14:31
If they are properly glued, I think so.
But why don’t you grout the area where the machine will be installed first? If the machine is still standing in the room, you won’t be able to grout continuously anyway and will have to move it out of the way in between.
