Our new build is currently under construction, being delivered as a turnkey project. All electrical wiring in the basement is installed surface-mounted, which is quite common for basements.
However, I am considering converting one basement room into a home office in a few years, and I would like it to have a more finished, “livable” appearance. Therefore, I want to ask how complicated it is to later change from surface-mounted to flush-mounted installation. I am especially thinking about the ceiling light outlets and electrical sockets on the basement exterior walls.
Thank you in advance for your answers.
Baunovize
Baunovize
Baunovize schrieb:
However, I might want to convert a basement room into a home office in a few years, which should look reasonably “livable.” Baunovize schrieb:
At first, I considered a suspended ceiling, but with a ceiling height of 2.30 meters (7 ft 7 in), that probably isn’t an option. Many building codes require a minimum ceiling height of 2.40 meters (7 ft 10 in) for living spaces. What about window size? Means of egress?
Baunovize10 Aug 2020 11:17Hello again,
thank you very much for your responses and interesting suggestions. The light outlets will now be drilled through the ceiling after all, which I am very happy about. Since the sockets in the basement are otherwise surface-mounted, I will take up your suggestions to make the basement feel more comfortable, even though it is, of course, not a traditional living space.
Baunovize
Baunovize
