ᐅ Basement Construction with High Groundwater Levels (2 meters)
Created on: 27 Sep 2023 11:18
pxrunes2
This is our first house, so we lack some experience. The soil survey revealed a groundwater level of 2.2 meters (7 feet) during midsummer. Throughout the year, there are probably levels around 1.6 meters (5 feet). Otherwise, the soil is sandy.
Bohrung 1: Bodenschichten - Mutterboden, graubrauner Feinsand, grau Mittelsand, gelbbrauner Feinsand
We would like to build a basement anyway, with small windows above ground level. A lower ceiling height of 2.2 meters (7 feet) would still be acceptable for us, since it will not be a living basement.
Our question now is whether building a basement is still financially feasible.
- How deep is an excavation typically dug?
- Does anyone have experience with how much more expensive a basement can become due to high groundwater?
- Any other advice?
Many thanks!
11ant27 Sep 2023 12:59
pxrunes2 schrieb:
I had hoped that by raising the basement slightly, it would still be cheaper than increasing the living space of the house. But as you describe it, and as I feared, the construction work is especially expensive and unpredictable.
I already "revealed" in post #4 where I am currently discussing the basement topic (regarding yes/no/which type, but without the special aspect of water). You should have been able to read here multiple times that rooms cost a fixed amount regardless of their location.
WilderSueden
27 Sep 2023 13:39
pxrunes2 schrieb:
- Any other advice?
Building in groundwater conditions allows no mistakes. Therefore, you should carefully select the construction company and have this work closely supervised. For more details, @Allthewayup can certainly help. It’s not cheap, of course. On the other hand, it’s better to plan from the start with a basement in groundwater than to build normally and then have to arrange water control measures on short notice, resulting in considerable additional costs.
27 Sep 2023 14:22
pxrunes2 schrieb:
The plot allows for a larger house,
Well, I would suggest building more cautiously and creating usable space as an extension or in the attic, for example under a nice pitched roof. A sports room or hobby area also makes sense with garden access and real windows, so preferably on the ground floor.
pxrunes2 schrieb:
but actually living space is more expensive again
Here the focus is on usable space, not on finished living areas.
pxrunes2 schrieb:
I had hoped that, if you raised the basement a bit
However, this creates a barrier between the ground floor and the garden/access points. The terrace then has to be on a hill, and the entrance platform consists of several steps. That’s usually not desirable. If you are planning a double garage anyway, rooms can be connected to it. That’s also better for storing lawnmowers and similar equipment.
kati133727 Sep 2023 16:43
I would also recommend checking in advance how your protection is covered by a homeowners insurance policy.
If the basement is built directly in the water, you will probably have a hard time in the event of water damage, or you will face lengthy procedures and proof that the measures taken to protect the building were sufficient.
Tolentino27 Sep 2023 18:01
Regarding storage space in a pitched roof, it’s a good idea to hire a studio binder. Unfortunately, I missed that advice (and I also ended up being persuaded to go for a hip roof villa style when I was still inexperienced and naive). By the way, there are quite nice example photos of this here in the forum.
I’m not sure anymore if they were posted by @Steffi33, @motorradsilke, or @haydee?
11ant27 Sep 2023 18:10
Tolentino schrieb:
I'm not sure anymore if it was from @Steffi33, @motorradsilke, or @haydee?
The tidiest attic of all time is the one from @Steffi33
