Kellerkino8 Oct 2017 11:32Hello everyone,
I would like to ask how to soundproof a home theater in the basement, especially regarding bass isolation, and which materials are suitable for this purpose.
Thank you very much!
Kellerkino9 Oct 2017 08:07Good morning KingSong,
Acoustic engineer, then I am perfectly in good hands with you!
By now, I also see bass as my enemy in the house, and that it’s not really controllable. I have considered a room-within-a-room solution, but so far I have failed because the existing room is not large enough. What is your opinion on this? How much space/distance/air gap does a room-within-a-room solution need to work properly, and how is something like that constructed?
Alternatively, which materials absorb sound, or with which materials could I at least achieve some reduction, or is that basically not possible? Every decibel (especially of bass) that I can reduce in the home theater room counts for me, in order not to disturb the family. If a reduction is possible with some effort, I’m in; but if it’s just a cosmetic measure, it’s pointless.
Thank you!
Thank you!
If a room-in-room solution isn’t possible, I would suggest trying the following. Take a look at the Lignotrend acoustic panels. They also have an acoustic calculator on their website. Acoustic panels combined with thick mineral wool insulation behind them will definitely transform your room into both an acoustic and visual experience! But be careful: the better the room sounds, the quicker you’ll notice if the speakers are low quality. However, controlling the transmission of low-frequency sounds to the rest of the house will only be moderate with this approach, but it’s better than nothing.
I once worked for a while in a recording studio located just 50 meters (165 feet) next to a commuter train track. The focus there was primarily on preventing outside noise from entering. This was achieved only through a room-in-room construction, where the inner room was mounted on rubber supports and completely decoupled from the rest of the building.
Deliverer9 Oct 2017 09:12What might also help: decoupling bass-producing furniture from the floor.
This not only improves sound quality but also prevents vibrations from spreading directly into the building structure.
You can easily check if this is an issue for you by placing old, thick carpet scraps, thin mattresses, or similar materials under the subwoofer and speakers, then comparing the difference.
For a permanent solution, there are various options on the market, ranging from affordable rubber feet to expensive spike systems.
However, this does not help with airborne noise. To reduce that, suspending the ceiling with an air gap followed by mass (such as bitumen boards on a supporting frame or similar) and (for good sound quality in a home theater) an additional layer of air in the form of pyramid foam might be effective.
Kellerkino10 Oct 2017 09:43Thanks, guys, for the information!
The Lignotrend walls look very appealing and expensive.
FYI:
Basement room
- Precast concrete basement (reinforced concrete)
- Exterior: polystyrene insulation, bitumen, studded membrane, gravel backfill, drainage all around
- 2 ducts, 100mm (4 inches) diameter, leading outside
- 1 opening, 10x10cm (4x4 inches) in the technical room
- 2 basement windows, each 100x60cm (40x24 inches)
- Floor tiled with underfloor heating
- Connections for water, sewage, satellite, internet
- Empty conduits in all four corners for hanging speakers
- Interior walls approx. 10cm (4 inches) thick
- Not rectangular, with two slopes on one side
- Door in the sloped wall
- Projection screen opposite the sloped walls
- Seating near the sloped walls
Currently:
- Ceiling with cheap ceiling panels
Unfortunately, I don’t have permission to upload a photo, but maybe that will come later.
FYI:
Basement room
Currently:
