ᐅ Base insulation cover XPS/dimple membrane
Created on: 28 Apr 2015 08:29
mundele-1
mundele-1
28 Apr 2015 08:29
we are insulating our exterior wall and I have installed 120mm (5 inches) XPS boards as perimeter insulation, which extend about 40cm (16 inches) into the ground and about 20cm (8 inches) above it. A dimpled membrane is applied over these and then backfilled.
Above that, 140mm (6 inches) mineral wool insulation boards will be added.
Now to my question:
As far as I know, the dimpled membrane is pulled up above the ground level. How can this be properly covered or concealed so that the splash water area is finished neatly?
Attached is a sketch for illustration:
Thank you very much for your help.
Roman-1
4 May 2015 17:03
Hi mundele,
I'm not an expert here. Off the cuff, I would cover it with drainage fabric.
Nicole1981-1
14 May 2015 14:53
Roman schrieb:
My initial gut feeling would be to cover it with drainage fleece.
However, this fleece should be the dimpled type. I would suggest the following setup:
Concrete, then fully apply XPS insulation boards, and finally the dimpled membrane.
seiler-1
8 Jun 2015 16:02
It is important to work with precision here. Mistakes can become quite costly in the end. Anyone without experience in this area should hire a professional company.
