Has anyone tried to get funding from BAFA for an air-source heat pump? The seasonal performance factor is set so extremely high that it seems practically unattainable.
Regards
Regards
Bookstar schrieb:
Since you can't achieve 4.5 with an air source heat pump, the probability is 0%. Information or not.
Good luck You are obviously misinformed...
Duran schrieb:
Quick question – how does the proof of the seasonal performance factor actually work? I applied for an air-to-water heat pump and received the approval; but we live in the Alps, so definitely the same temperature range You don’t need to provide proof that it really reached 4.5. At least that was the case last year. It wouldn’t make sense anyway, since the first year isn’t very conclusive because things like the heating-up program run at flow temperatures that are significantly higher than those later on.
ares83 schrieb:
You don’t need to provide proof that it actually reached 4.5. A calculation according to VDI always needs to be provided. The values actually achieved in practice largely depend on user behavior and are therefore irrelevant for the subsidy.
Regards, Nika
gnika77 schrieb:
A calculated verification according to VDI standards must always be provided. The actual values achieved in practice largely depend on user behavior and are therefore irrelevant for funding purposes.
Regards, NikaAnd how did you manipulate it? I have the most expensive inverter Novelan heat pump and achieve about 4.2 in calculation. Where is the mistake?
Bookstar schrieb:
And how did you manipulate it? I have the most expensive Inverter Novelan heat pump and calculate about 4.2 COP. Where is the mistake? Nothing manipulated. Just proper planning/design of the heating system and a suitable heat pump.
Give me your
NAT, VLT, heating limit temperature, and heat pump model, then I can tell you what you could have done differently, if anything at all...
Regards, Nika
Grantlhaua25 Mar 2019 06:46gnika77 schrieb:
The funding requires achieving a seasonal performance factor (SPF) of at least 4.5. Until March, this could still be calculated using the old version of the VDI guideline. From March onwards, however, it must be calculated according to the new VDI guideline. The new calculation method is closer to real-world conditions. Therefore, the SPF values are generally lower.and once again, our heating installer missed this...
gnika77 schrieb:
P.P.S Under no circumstances install a heating buffer tank with a heat pump.This is not entirely correct. Of course, there are applications where a stratified storage tank can be useful.
