ᐅ Bathroom Renovation – Which Manufacturer for Sanitary Fixtures?
Created on: 23 Jan 2021 15:32
Simon91
we are currently renovating our bathroom and are now looking for:
1 bathtub
1 toilet
1 washbasin
The selection is huge, but I would prefer all products from the same manufacturer.
Villeroy & Boch is one option. Does anyone have experience with bathtubs from this manufacturer, for example from the Subway or Collaro series?
Which other manufacturers are there, or which have you chosen?
Thanks, regards
1 bathtub
1 toilet
1 washbasin
Thanks, regards
borderpuschl27 Jan 2021 11:18A standard connection set will fit here. 110mm (4.3 inches) is common, and the Venticello has 102mm (4 inches), which is also standard. For the supply line, however, it should be 45mm (1.8 inches). Please measure again carefully, as 45mm (1.8 inches) is the standard for Geberit.
Perfect, you have helped me a lot. I have one last question.
There are two different sinks from the Subway series, one comes with a template and the other does not (item numbers 711360 and 71136G).
We want to mount the sink on the wall and combine it with an Ikea vanity cabinet. Do you know what the differences are between the two?
nordanney27 Jan 2021 12:00Mat350ze schrieb:
Do you know what the differences are between these two?This is the difference. One basin can be used as a countertop basin due to its polished (and therefore flat) underside. The other is designed for traditional wall mounting.
nordanney schrieb:
However, every manufacturer and product line has different actuator plates. Oops. Yes, that’s what I meant—I have often read that this can be a problem 🙂
