ᐅ Bathroom half-height tiling. Floor tile used as a shelf on the stud wall.
Created on: 13 Oct 2017 16:13
Malz1902
We plan to tile our bathroom halfway up, 1.20 meters (4 feet) high. The wall construction in front is 1.20 meters (4 feet) high. The floor tile will be placed on top of this wall as a shelf. The question is whether we should also tile an additional 10 cm (4 inches) on the wall behind it. Our site manager said this would make cleaning easier since you wouldn't be cleaning directly against the wall.
Joedreck
14 Oct 2017 11:23
We also had the so-called “wiping edge” tiled. It doesn’t look too bad at all.
But be careful with a continuous enclosure: if there’s a mirrored cabinet above the washbasin, you end up with a very awkward surface to clean that’s hard to reach.
For the edges when tiling, I would definitely recommend using a stainless steel edge.
Bau-Schmidt
14 Oct 2017 12:01
But not where there is a platform!
For you.
Malz1902
14 Oct 2017 12:13
Joedreck schrieb:
We also had the so-called wet edge tiled. It actually doesn’t look bad at all.
But be careful with a continuous ledge: if there’s a mirrored cabinet above the washbasin, you end up with a very awkward surface that’s hard to clean.
And for the tile edges, I would definitely recommend using a stainless steel edge trim.
Thanks, could you maybe take a photo?
I don’t want a mirrored cabinet anyway, just a simple wall mirror. My girlfriend wants a mirrored cabinet, but then that won’t be possible.
truce14 Oct 2017 12:43
Malz1902 schrieb:
I don't want a mirrored cabinet anyway, just a simple wall mirror. My girlfriend wants a mirrored cabinet, but then we won't have that.
Then just choose a recessed mirrored cabinet.
It looks like a simple mirror, but you still have storage space.
11ant14 Oct 2017 15:11
truce schrieb:
Then just take a mirrored cabinet and recess it into the wall
Honestly, I find mirrored cabinets pretty outdated. When it comes to bathroom mirrors, the main purpose is to check shaving or grooming/makeup results. I don’t see a necessary connection with storing band-aids, headache tablets, or spare toothbrushes. In my opinion, these are two different needs for which I don’t see any advantage in a combined unit.
14 Oct 2017 16:15
Bau-Schmidt schrieb:
Your turn.
Yes, because I find it more aesthetically pleasing and useless as a corner bead.
The original poster asked for opinions – and I’m sharing mine.
