ᐅ Avoid moisture buildup behind cabinets
Created on: 17 Aug 2020 11:52
frankmehlhop
frankmehlhop
17 Aug 2020 11:52
I want to place a kitchen against a wall that is covered with lime plaster and silicate paint.
It is a ground floor room without a basement, and I have to expect that this wall may become damp during heavy rainfall. Normally, the moisture can dry into the room, but if furniture is placed in front of it, that won’t be possible.
I have some ideas such as
  • leaving a gap between the wall and the furniture (about 10cm (4 inches)), but I don’t think that is a nice solution
  • installing a pipe with holes along the bottom of the wall, where a hairdryer or similar device could blow warm air in (depending on the season, temperature, etc.)
Is there perhaps a professional solution to this problem?
What would you do?
nordanney
17 Aug 2020 12:42
Kitchen without wall cabinets (which I find more attractive anyway) and with a deeper countertop on this wall. This way, you have more workspace on the countertop, and the cabinets are not placed directly against the wall. Also, make sure to heat and ventilate properly.
Mycraft17 Aug 2020 13:47
Heating and ventilation solve most problems.
frankmehlhop
17 Aug 2020 14:26
I forgot to mention that the house is occasionally unoccupied. Therefore, it is only heated irregularly during winter, and ventilation is also done only occasionally during that time.
