helloBavaria23 Jan 2024 15:15Hello everyone,
Basically, I will avoid home automation for cost reasons. The only thing I would like is smart roller shutters, to quickly darken all windows in the summer when it gets hot, for example.
I would prefer to avoid devices like Shelly or similar if possible. It shouldn’t be a DIY solution but still as affordable as possible.
Does anyone have any suggestions on what would make sense?
helloBavaria23 Jan 2024 15:27Has anyone here ever implemented their own automation system, for example with a Siemens controller? In principle, I could also consider installing a PLC in the distribution board. I would be able to handle the programming myself.
helloBavaria schrieb:
I would like to avoid using Shellys or similar if possible; it shouldn’t be a DIY workaround but still as affordable as possible.Have you already looked into this? I find a solution using Shellys to be far from what I would call a "DIY workaround." It works really well, is reliable, is hidden from view, can be operated by everyone, and is affordable.H
helloBavaria23 Jan 2024 17:23Pacmansh schrieb:
Have you already looked into this topic? I consider a solution using Shelly devices far from being a “DIY hack.” It works really well, reliably, is discreet, can be operated by everyone, and is affordable. Actually, not in detail; I’m just a silent reader in another forum.
I wouldn’t question it for renovations or similar. But for a new build, where I still have full control over the wiring, in my opinion it’s not the top solution. Or do you see it differently?
No, I agree with that. For new builds, it's not the top solution. If there is enough time, budget, and good planners available, I would prefer other options, but of course also do more than just blinds.
However, if a full smart home system is not desired at first and only the blinds are to be controlled, I would still consider this as an option for new builds. The wiring can be routed to the distribution board regardless.
That said, I am not familiar enough with the other systems to make a direct comparison.
jens.knoedel24 Jan 2024 09:38helloBavaria schrieb:
Basically, I will forego home automation for cost reasons. helloBavaria schrieb:
But for a new build, where I still have full control over the wiring, in my opinion, it’s not the best solution—unless you see it differently? Your statements seem somewhat contradictory. No budget for extra features, yet standard Shelly applications are too cheap/simple for you?
You either invest the money or work with common wireless solutions (whether Shelly or other more expensive systems).
