ᐅ Attachment of Pergola to Wall and Floor
Created on: 19 Aug 2025 10:36
Prager91
Prager91
19 Aug 2025 10:36
In the next two weeks, our ordered pergola will be delivered (Dutch manufacturer – not the “big” one, but another).
For wall mounting as well as floor mounting, M10 bolts with standard anchors are provided and included.
I already inquired about this: these are not fish-eye anchors, so not cheap brands.
Wall mounting: M10x70mm (M10x2.8 inches)
Floor mounting: M10x80mm (M10x3.1 inches)
Since our insulation alone is 12cm (5 inches) thick, followed by the 36.5cm (14.4 inches) brick wall, I would need at least M10x140mm (M10x5.5 inches) – what do you think?
For the floor, the M10x80mm should definitely be sufficient.
My question now (especially for the wall) is, what exactly should I use here? What would be the optimal bolt length? Which anchors should I use? Heavy-duty anchors? And which size exactly?
I assume I can use the bolts for the floor mounting. Which anchors would be best suited for the concrete foundation there?
Looking forward to your input!
Prager91
19 Aug 2025 11:17
Addition: After the insulation, there is concrete (so I would drill in from the outside, through the insulation and then the concrete slab). No bricks are used.
Arauki11
19 Aug 2025 12:50
What does the manufacturer say about it?
Prager91
19 Aug 2025 13:13
It’s more of a small language barrier—technically a bit challenging, to be honest.
Since every facade assembly is different and this concerns fastening materials, unfortunately, there is no universal solution. It definitely needs to be adapted to the specific requirements and conditions on site.
I’m also worried that if I use a sleeve anchor of the proper length, I might compress or damage the insulation when tightening it.
NeoTheOne
21 Aug 2025 19:53
There are special systems to prevent damage to the insulation. You cannot use regular anchors and screws for this. Just search for "spacer mounting system ETICS" online.
