ᐅ Securing Heavy Items to a Drywall Partition
Created on: 18 Dec 2025 19:59
tadeus321
tadeus321
18 Dec 2025 19:59
I have a drywall partition wall made of a gypsum fiberboard with a Funderplan board underneath. (It’s similar to an eco-friendly OSB board but much thinner and denser.)
A kind of frame needs to be attached to this wall, which must support a permanent load of 60kg (132 lbs). The load has to be carried by the wall. There is no connection to the floor. What kind of fasteners or special anchors can be used for this?
Regards
11ant19 Dec 2025 00:38
Thanks to Artur Fischer, you don’t have to worry about wall cabinets. The man didn’t just invent the toggle bolt.
If you’re looking for a belt to go with the suspenders, add Würth to Fischer ;-)
We understand everything except Standard German.
neo-sciliar
19 Dec 2025 14:45
tadeus321 schrieb:
a kind of frame
A shelf?
Usually, the issue is not the wall structure itself, but the attachment of the panels to the substrate. Otherwise, load capacities of gypsum fiber and OSB boards can be found online (for this, you should know the panel thickness and the support structure of the panel).
