ᐅ Mounting a pull-up bar on a lightweight clay block wall... good idea?
Created on: 10 Apr 2020 11:27
Alderney
Alderney10 Apr 2020 11:27
Hello dear forum,
I would like to install a pull-up bar in my basement. The interior walls suitable for this (like most of the house walls) are made of expanded clay blocks (Liapor), which are said to have somewhat lower strength compared to regular bricks. The bar will be mounted to the wall using eight 12mm (1/2 inch) screws. Does anyone have experience with this material, or can I do this (possibly only with specific anchors)? Or will the bar come off the wall during use (and I with it...)?
Thank you very much and best regards
Vicky Pedia10 Apr 2020 12:01
I think your question is justified. Screw the rod to 1.50 m (5 feet), nothing can go wrong.
But seriously. The stone manufacturer has a hotline and they know how to do it. If necessary, there are installation professionals available as well. They can provide advice too. It will probably come down to bonding with epoxy resin. However, I don’t want to give you incorrect advice.
Musketier10 Apr 2020 12:05
For our staircase, core drilling was done in the aerated concrete, then the holes were filled, and the steps were anchored into them to prevent the individual steps from shifting.
M4rvin10 Apr 2020 13:46
Just give it a try and set up a camera; with a bit of luck, you’ll create a great fail video!
