ᐅ Mounting a Satellite Dish on the Wall or the Roof? Timber Frame House
Created on: 25 Nov 2016 13:15
world-e
world-e
25 Nov 2016 13:15
I would like to hear your opinions regarding the installation location of a satellite dish. The corner of the house between the eaves side and the gable side faces almost exactly south. The gable side faces southwest and the eaves side faces southeast. The house will have a pitched roof with two full stories and a 25° roof pitch, built with timber frame construction. Would you rather mount the satellite dish on the roof or on the wall? If the dish were attached to the gable, thermal bridges would probably be negligible since the roof is not insulated. But what about wind load? The externally applied wood fiber insulation panels are 120mm (5 inches) thick. With roof mounting, lightning protection would be more critical, and it would be harder to access. Thank you very much.
Alex85
26 Nov 2016 11:04
"Professionals" always recommend the wall instead of the roof. It’s easier to access, protected from weather and snow, and there’s no hassle with penetrating the roof surface, etc.
What this means for a timber house, I’m not sure.
Dipol
28 Nov 2016 02:16
Alex85 schrieb:
"Professionals" always recommend mounting on the wall rather than the roof.
I am an antenna expert and, depending on the specific case, I much more often recommend roof antennas rather than wall antennas. With 12 cm (5 inches) wall insulation, installing a wall bracket, for example using a THERMAX system, is significantly more complex than installing a rafter mount, which is also compatible with any future roof insulation.
Alex85 schrieb:
Easier to access, protected from weather/snow, no hassle bringing anything through the roof membrane, etc.
The claim that the antenna is easier to access at the gable position planned by the original poster may or may not be true; stated so generally, that is wishful thinking.
In alpine regions, it might still make sense to install antennas under wide roof overhangs for snow protection. But where in flatland areas does it still snow so heavily that the antenna needs to be cleared regularly? With proper planning, access from a roof window can also be easier than from a façade window.
Antenna cables led through insulation in the roof or on the wall must be equally windproof. A professional resolves this easily and reliably without the need for makeshift solutions.
Alex85 schrieb:
What this means for a timber house, I don’t know.
The creators of the so-called safe protection zone on façades according to IEC 60728-11, defined as ≥ 2 m (6.6 feet) distance below the roof edge/gutter and a maximum 1.5 m (5 feet) from the wall, most likely did not consider soft roof coverings or timber construction.
Preventive safety notice:
Antennas installed outside the defined safe façade zone must be capable of carrying lightning current and must be connected and grounded to the building’s equipotential bonding system.
world-e
28 Nov 2016 07:17
Thank you for the explanation. A gable installation would be easier to access since you wouldn’t need to go onto the roof; a ladder would be sufficient.
In the case of a later photovoltaic installation, a satellite dish on the roof could also be obstructive.
world-e
6 Dec 2016 11:04
One more addition:
Option A is not very popular with my partner because the satellite dish would be too visible from the terrace. The same issue would likely apply to option D. Perhaps option B would be better after all. Or on the garage, but that could cause sealing problems if the satellite dish is placed on the flat roof, and it would also require longer cable runs.
Top-down Grundriss eines Hauses mit Garage und Terrasse und roten Markierungen A-D
Schrauberking
29 Jan 2017 18:40
You can address the issue of thermal bridging by using the appropriate type of anchor. For wind load and varying forces, I would recommend fastening to the exterior facade. This will deliver as promised. It is primarily designed for awnings and other heavy loads. Keep in mind: drilling properly into brick (if present) is half the battle.
