I could well imagine using the Besta TV bench to accommodate an AV receiver, Blu-Ray player, satellite receiver, etc. However, the whole setup should have a front panel. But how does the 26mm (1 inch) front fit with a height of 32cm (12.6 inches)? Maybe someone has a picture of their solution. Thanks in advance.
Good luck
Judoka
Good luck
Judoka
IKEA-Experte25 Oct 2013 10:42Hello,
the 26 cm (10 inches) front actually doesn’t fit at all. The bench is 320 mm (12.6 inches) high, the front is 256 mm (10 inches). That leaves 64 mm (2.5 inches). Subtracting the 31 mm (1.2 inches) countertop thickness leaves 33 mm (1.3 inches) free. That probably won’t look good and won’t be practical to use. For this bench, only the 16 cm (6.3 inches) fronts are practical to use.
