ᐅ Assessment of Previous Consumption
Created on: 16 Sep 2020 08:13
Tx-25
Hello, what do you think about the consumption so far?
The heating has been running since around May 25, 2020.
The heat meter for the domestic hot water circuit was installed approximately 4 weeks later.
Is it really possible that our 9.92 kWh photovoltaic system has already generated 4,800 kWh? Unfortunately, I cannot check the data via an app yet, as we still do not have internet access.
Tx-25
16 Sep 2020 09:12
The photovoltaic system has been running since April 9th, 2020.
We have the system installed on both sides of the roof (essentially east-west orientation) with a 45-degree roof pitch.
The screed heating was actually included. It was not powered by our air-to-water heat pump but by an external device. However, the electricity consumption was of course recorded by the electricity meter.
Unfortunately, the SMA inverter does not have a separate display. The readings are available later via an app. For this, I need a Wi-Fi network. That will take some time due to the telecom provider. The inverter creates its own Wi-Fi network, but I can’t use it to install an app or establish a connection.
Currently, I can only read the consumption data through the IP address.
However, the data there is all mixed up. Among other issues, the date is also incorrect. When I try to adjust it, nothing happens. So at the moment, I cannot accurately determine what the system produced yesterday.
What do you think about the 60.05 kWh of pure heating consumption? Unfortunately, the heating ran in some rooms during the summer due to incorrect settings. Apart from that, so far it has only been used for hot water.
