ᐅ Assessment & Assistance for a Semi-Detached House, Approximately 180 sqm, DIY Floor Plan
Created on: 10 Feb 2023 13:28
Mar_Mar
we have purchased a 337 m² (3623 ft²) plot on which we now want to build our semi-detached house. We are in discussions with various construction companies, but their approaches vary widely. Since we are often presented with floor plans based on our key specifications that we don’t like at all (often a standard run-of-the-mill semi-detached house), we have started to think about it ourselves. It’s also quite different that one company has a problem with the structural engineering for a ground floor measuring 8 x 12 m (26 x 39 ft), while another does not. Our wish is also to have the technical equipment on the attic floor (see separate thread).
Now I would like to get your opinion on our DIY floor plan. Does it make sense? What have we overlooked? Constructive suggestions are welcome, as I don’t really like, for example, the bathroom/office solution on the upper floor.
Development Plan/Restrictions
Plot size: 337 m² (3623 ft²)
Slope: no
Site coverage ratio: 0.35
Floor area ratio: 0.7
Building envelope, building line and boundary: 12 m length (39 ft), plot is 11.5 m wide (38 ft), so effectively 8.5 m (28 ft)???
Edge development
Number of floors: 2.5
Roof style: pitched roof, 30 degrees, no knee wall
Architectural style
Garden side facing fully south
Maximum heights/limits: 12 m length (39 ft), 6.5 m eaves height (21 ft)
Further requirements: adjacent semi-detached house will also be built later without a basement with dimensions of 8.5 x 10.1 m (28 x 33 ft), smaller than ours
Homeowners’ Requirements
Architectural style, roof shape, building type: no special requirements
Basement, floors: no basement, 2.5 floors
Number and age of residents: 38, 38, 2, x 😉
Room requirements ground floor, upper floor: ground floor airy, bright, spacious; upper floor 3 bedrooms, bathroom, office
Office: family use or home office? Home office
Number of overnight guests per year: a couple every three months or so
Traditional or modern construction: modern
Open kitchen, cooking island: open with island
Number of dining seats: 6
Fireplace: no
Music/sound system wall: no, TV on wall
Balcony, roof terrace: terrace (added later)
Garage, carport: none, as garage space here is very disadvantageous
Utility garden, greenhouse
Additional wishes/special features/daily routine, including reasons why something should or should not be
- House technology preferably in the attic since we usually spend most time on the ground floor and want plenty of space there
- Avoid standard floor plan with U-shaped staircase if possible, therefore the compromise of a V-shaped staircase with glass railing on the ground floor, open without storage under the stairs, winding stairs connecting ground floor and attic
- Lots of window area, lift-and-slide windows on the ground floor with external blinds because of south-facing side
- Kitchen and lounge somewhat separated and not too close to each other
- Ceiling height on the ground floor at least 2.65 m (8.7 ft)
- Make use of sloped ceilings in the attic space
Who designed it: DIY
What do you like most? Why? Open living space, open stairway
What do you dislike? Why? Bathroom/office on the upper floor
Price estimate according to architect/designer: 450k
Personal budget limit for house, including fittings: 550k
If you have to give up on something, which details/extensions
- Can be waived: pantry on ground floor, “even more” windows
- Cannot give up: separate office
Why is the design the way it is now? For example,
A mixture of many examples from various magazines…
What do you think makes it especially good or bad? Good because it is not standard and conveys a generous, bright sense of space
Slope: no
Edge development
Architectural style
Fireplace: no
Mar_Mar schrieb:
Ok, so I understand correctly that it’s better for the air source heat pump to be placed at the bottom left in front of the house (facing forward), and that the cables should be routed in a zigzag pattern upwards rather than straight up? No, in my case and in my planning, there is no zigzag routing of cables. Conduits run straight up where they do not interfere (->central wall).
Mar_Mar schrieb:
There is hardly any space left for a cabinet. The central wall. However, you lose cabinet space due to the position of the doors on the right side of the plan.
Mar_Mar schrieb:
As far as I know, there is a mathematical formula to calculate how many square meters of window area are needed for a specific room. That is purely theoretical and applies to minimum requirements. I want to point out that it is _your_ wish to build with an airy and spacious or similar impression…
Mar_Mar schrieb:
Where could an open sightline be incorporated? I already posted that on the ground floor. Yes, it was an attempt with a gallery to capture roof light, but it does not have to be implemented.
Mar_Mar schrieb:
Yes, I expect some investment when they want me to sign something that costs 500k and will be the biggest investment of my life. Cheers to your expectations. We’ll see if they are met with a general contractor.
Here’s to your expectations. We’ll be curious to see if they are met with a general contractor. Yes, there will probably be a learning curve. What can you expect from a first offer? Most likely, no one will create a detailed floor plan for you. Not everyone is as obsessed as we are – sellers need to sell, not entertain. If you’re lucky, the provider already has three plans from previous clients who built something similar. They’ll adapt one to your size, maybe move a few walls, and then give you a proposal. But most will just provide measurements, maybe a rough sketch of the ground floor that you designed yourself, and a cost estimate. Otherwise, it’s mainly about feasibility regarding materials, workmanship, timing, the plot, building permit / planning permission, and similar factors. An architect only gets involved once you pay for their services.
If that’s important to you (as it is for me), you first hire the architect of your dreams and pay a (significant) amount upfront for the design. That can take a while. With the finished design, I then shop around and ask which builders can execute that specific project. Many new homeowners, however, are discouraged by the initial costs and then settle for some third-rate junk that a draftsman quickly put together somewhere, and they, as amateurs, fumble around with it for weeks.
goalkeeper24 Feb 2023 09:3211ant schrieb:
I believe that @goalkeeper has an outdoor unit mounted on his gable wall.Nope… it’s standing on the ground at the side parking space.
