Good evening,
About three years ago, I removed the carpet with foam backing and the kitchen floor, which was a type of vinyl, in my apartment built in 1982/83. A floating hardwood floor was then installed on top, and the baseboards were taped off.
At the time, I did not consider that the carpet, adhesive, or vinyl might contain asbestos. Now, three years later, I realize that I handled the removal rather carelessly, pulling everything up and scraping it out.
I would like to find out if I released asbestos back then or if asbestos is still coming up from under the new floor into the indoor air.
I still have one piece of carpet remnant with adhesive. However, several different carpets had been installed.
From my research online, I learned that dust sampling (stamping) or material testing can be done. However, I would prefer not to remove the newly installed flooring again. My main concern is whether there is an immediate health risk in the current situation. Therefore, I would appreciate your opinion on how you would proceed to clarify the situation.
Thank you very much.
hampshire29 Jun 2019 00:05If you are concerned: have it measured.
MasterXX12329 Jun 2019 03:16Asbestos is only released when it is disturbed or worked on, or am I mistaken?
Stivikivi1 Jul 2019 22:24It is definitely bad, but no one gets sick from a short-term exposure. Okay, unless you briefly come into contact with uranium, but that is something completely different, right?
