ᐅ Are your KALLAX doors also becoming loose after just a few weeks of use?
Created on: 23 Oct 2023 19:07
pedan
pedan
23 Oct 2023 19:07
A few weeks ago, I fitted my IKEA KALLAX shelves with the matching doors and noticed that at least one of the doors became loose relatively quickly. The locking mechanism no longer seems to hold as firmly under everyday use as it did initially. My question for you: have your KALLAX doors also become loose after just a few weeks of use? If so, how do you handle this issue, and is there a specific trick or adjustment technique that really helps? I have already adjusted the doors several times, but the looseness always seems to return.
I would appreciate it if you could share your experiences, especially regarding durability and everyday use, so I can judge whether this is a general issue or if I might have made an installation error.
Dilen
23 Oct 2023 20:34
pedan schrieb:
Have your KALLAX doors also become loose after just a few weeks of use?
This is actually an issue I have looked into thoroughly as well. The hinge and mounting system of the KALLAX doors is quite simple, but that is often where the problem arises.
First, it’s important to note that the door hinges at IKEA typically have an adjustable mounting plate that is secured with small screws. If these screws are not tightened firmly enough or if there is slight vibration during everyday use (e.g., from regular opening and closing), the screws can easily loosen. This causes the door to lose its tension and feel “loose.”
I recommend tightening the screws on the mounting plate during installation so that there is minimal play. If they still loosen over time, using a small amount of medium-strength threadlocker can help prevent loosening permanently.
Equally important is to check the hinge structure on the door itself. Is the metal hinge and the plastic anchor in the door stable? In my experience, plastic sleeves inside the door can sometimes become worn out, which can similarly cause the door to feel loose.
One tip: If your hinges have micro-adjustment features, you can use them to fine-tune the door’s position and ensure it fits snugly against the unit. How do the screws look on your end? Are they all firmly tightened with no noticeable movement?
Have you checked whether any warping of the frame due to uneven stress or misalignment might be contributing? This can also cause doors to loosen more quickly.
bapar
23 Oct 2023 21:12
pedan schrieb:
I have adjusted the doors several times by now, but the looseness seems to come back repeatedly.
From my experience, this is a typical issue with KALLAX doors. The hinges themselves are basically simple, with only two or three mounting points. This means that the force exerted through frequent opening and closing puts a relatively high load on the connection.
What helped me was not only tightening the screws but also ensuring an even and precise distribution of tension when securing the hinges. Some hinges can be adjusted laterally, allowing for fine alignment. If this fine adjustment is not set correctly, the door can hang crookedly, which in turn causes additional stress and thus loosening.
Additionally, I regularly checked the adjustment screws—ideally every two weeks at the beginning until you get a feel for how the component behaves. The surrounding rubber gasket can also lose elasticity over time, which can create more clearance for movement.
A minor tip: Sometimes it also helps to completely remove the hinges along with the mounting plate, pre-drill the screws again (if possible, closer to the core wood), and then reinstall them with firm torque.
How often do you open your doors on average? In an office environment, for example, 10 to 15 times per day can already have a significant impact on fine mechanics, which on KALLAX requires more frequent adjustments due to the lighter material.
If you disassemble your doors completely, also check the screw holes themselves for fraying or elongation—that is sometimes the reason the doors feel loose.
pikin
24 Oct 2023 08:16
It is generally known that the hinge material and installation effort for IKEA shelves are designed more for basic functionality rather than long-lasting precision.
Yes, several users experience exactly these issues, which can be attributed to the following causes:
1. Screws loosen over time due to continuous stress
2. The hinge attachment on the door side shows signs of material fatigue
3. Misalignment of the doors causes uneven pressure on the hinges
A tip: Simply tightening the screws is often not enough. It is recommended to fill the screw holes in the wood with wood glue and wood shavings and then re-drill them to improve screw grip.
Additionally, it is important to regularly check the doors and readjust the hinges as needed. Ultimately, these are furniture pieces with a moderate price-performance ratio, where the material stability is not comparable to premium furniture.
Therefore, with frequent use, one should expect to perform small maintenance tasks regularly.
Elodie
24 Oct 2023 11:05
Hey everyone! 😊
I had the same problem with my KALLAX doors – it’s really frustrating when the hinges start to loosen after a short time. For me, it was because I didn’t tighten the screws firmly enough during installation.
Dilen schrieb:
If they still loosen, a small amount of medium-strength threadlocker can help
That really worked wonders for me! Because of the vibrations from opening and closing, the screws otherwise loosen quickly and the door feels like it might fall off at any moment. 😅
I also experimented a bit with the direction in which I aligned the door. An even distribution of pressure on the hinges makes the doors fit snugly and prevents wobbling.
My tip: Take about half an hour, tighten the screws properly, apply a small drop of threadlocker, and adjust the door carefully – it makes a lasting difference.
Sure, it’s not the most glamorous task, but if it works, it somehow makes the furniture much more durable – and it’s satisfying 😉
How about you? Does anyone have other tricks?
neoren
24 Oct 2023 14:27
Check the hinges to ensure the mounting screws are properly secured and tighten them if necessary. This is usually enough to prevent the doors from becoming loose.
