ᐅ Are there environmentally friendly options for painting Ikea HEMNES furniture?
Created on: 25 Oct 2023 09:37
tilmanka
tilmanka
25 Oct 2023 09:37
I am planning to refresh some of my Ikea Hemnes furniture and wonder if there are ways to refinish it in an eco-friendly manner. The HEMNES series is mostly made of solid pine wood and has a coating that, as far as I know, is solvent-based.
I am especially interested in:
- Which types of paints or treatments would be suitable to recoat the furniture environmentally friendly (e.g., water-based, low in VOCs, as non-toxic as possible)?
- How extensive is the preparation of the original coated surface to ensure good adhesion of an eco-friendly paint?
- Are there practical tips or experiences to keep in mind during application to ensure both protection and aesthetics?
I want to consciously avoid conventional solvent-based paints to keep my environmental impact low and work as health-friendly as possible.
I look forward to your expert advice and assessments!
RENMA
25 Oct 2023 10:12
to refinish HEMNES furniture in an environmentally friendly way, it is recommended to use water-based acrylic paints. These have significantly lower VOC emissions than traditional solvent-based paints and are often available at wood specialty stores or from eco-friendly suppliers.
A thorough preparation is essential: the old finish should be removed by sanding or at least lightly sanded to ensure good adhesion. Sanding between coats after the first application further improves the result.
It is also important to clean the surface thoroughly before painting to remove dust, grease, and residues.
Alternatively, natural oils or waxes can be used, which protect the wood without forming a paint layer. However, they are less durable against mechanical stress compared to conventional coatings.
In summary:
- Water-based acrylic paints with low VOC content
- Comprehensive preparation through sanding and cleaning
- Natural oil or wax applications are also possible depending on the desired finish
This combination works well for HEMNES furniture.
bapar
26 Oct 2023 08:51
Good morning,
I would like to add some technical details, as important aspects are often overlooked when treating painted HEMNES furniture in an eco-friendly way.
First, it is important to understand the original paint system. Ikea usually uses a UV-cured or water-based coating that is quite durable. Simply repainting without applying a conditioner or properly preparing the surface by sanding can cause adhesion problems and cracking.
My approach:
- Sand lightly with fine grit (120-180) to slightly roughen the surface, but do not sand down completely as this can affect the wood’s stability.
- Then thoroughly remove dust, ideally with a damp cloth and/or a tack cloth.
- Use a primer compatible with water-based topcoats, for example acrylic-based, and pay attention to low VOC levels.
- Apply at least two thin layers of paint, sanding between coats with 320-grit sandpaper.
For environmental friendliness, I recommend products certified with Blue Angel or similar labels. Ensure good ventilation during application, even if VOC levels are low.
It would be helpful to know the room climate and usage conditions: kitchens, children's rooms, and living rooms have different requirements for durability and maintenance.
If you have specific paints or brands in mind, I can check compatibility. Alternatively, natural resin paints made from plant oils are an ecological option, though usually less durable.
Have you already considered the desired gloss level? Matte, satin, or glossy?
Layla
26 Oct 2023 21:09
Hello tilmanka,
I completely understand your wish to refinish Ikea HEMNES furniture in an environmentally friendly way. I feel the same, as both the environment and a healthy living atmosphere are important to me.
Some time ago, I tried treating furniture with ecological paints myself. What I discovered is that it is possible, but it requires time and patience. Especially if you don’t want to completely remove the original finish on the HEMNES furniture, sanding and preparation can be quite challenging.
May I ask a quick question: Do you want to repaint the furniture completely, including changing the color, or just renew the protective coating? This is important, as many eco-friendly finishes tend to be more transparent or slightly tinted rather than strongly colored.
There are also oils and waxes that have less solvent odor and are better suited for people with sensitivities. However, they do not protect against moisture and wear as well as paint or varnish.
I think it’s a great idea to focus on environmental friendliness in DIY projects. Sometimes the process is a bit slower, but that makes it all the more rewarding.
Looking forward to more tips here.
Thierryzar
27 Oct 2023 14:02
To paint HEMNES furniture in an environmentally friendly way:
- Lightly sand the furniture
- Use water-based acrylic paint with low VOC
- Apply at least two thin coats
- Lightly sand after each coat
This improves adhesion and protects the wood. Done.
draleo
28 Oct 2023 12:45
LAYLA schrieb:
May I ask a quick follow-up question: Do you want to completely repaint the furniture, including changing its color, or just renew the protective coating?
I find this question very relevant, as the requirements vary depending on the goal.
To clarify: For a complete repaint, especially if changing the color, it is advisable to fully sand off the old paint layers. This prevents underlying layers from showing through or surface defects from remaining visible.
For environmental friendliness:
- Use products with certifications such as Blue Angel
- Water-based acrylic or polyurethane (PU) paints are recommended
- An alternative is natural hardwax oils (e.g., linseed oil-based), although these do not offer the same durability
Important: Drying times for environmentally friendly products can be longer because they contain little or no solvents. This should be taken into account in scheduling.
Additionally, ventilation during application and drying is crucial—even with low emissions.
Regarding preparation: Dust-reducing sanding methods (sanding fleece, non-sanding products) can help minimize fine dust and pollutants. The tools you have available are also an important factor.
I hope this helps.
