ᐅ Are there options to retrofit individual KALLAX doors with soft-close mechanisms?
Created on: 4 Jul 2021 13:27
nigi50
nigi50
4 Jul 2021 13:27
I am considering whether it is possible to retrofit individual KALLAX doors from IKEA with soft-close functionality. Specifically, I do not plan to equip the entire shelving system with soft-close hinges, but only certain doors that I want to close particularly quietly and smoothly.
Does anyone know if there are compatible soft-close hinges or retrofit kits that work with the original KALLAX doors and the system frame?
It is also important for me to know if installing these soft-close components can be done without major modifications or special tools, as I would like to keep the process as simple as possible.
Looking forward to tips, experiences, or recommendations! Thanks in advance.
Surela
4 Jul 2021 15:53
The idea of retrofitting some KALLAX doors with soft-close hinges is technically feasible, but there are a few important details to consider:
First, it’s important to know that IKEA KALLAX does not come with soft-close hinges by default; instead, it uses simple piano hinges, which operate quite smoothly. Retrofitting with soft-close hinges is therefore not a plug-and-play solution, as the existing hinges must be replaced with soft-close compatible ones.
nigi50 schrieb:
Are there compatible soft-close hinges or retrofit kits that work with the original KALLAX doors?
There are indeed third-party retrofit hinges available. These are generally designed for standard furniture hinge pins with a diameter of 35 mm (1.4 inches), which usually applies to KALLAX as well. Before purchasing, it is important to check the measurements of the drill holes on the inside of the doors and compare them with the technical specifications of the soft-close hinges, as some suppliers may have slight variations.
nigi50 schrieb:
Is it possible to install these soft-close components without major modifications?
If the drill holes are already present, a direct replacement can be done, which significantly simplifies installation. However, if the hinges require different hole patterns or depths, the old holes would need to be filled with wood filler and pre-drilled again, which requires some craftsmanship.
In addition, you will need a suitable screwdriver (usually a Phillips head) and possibly a drill with a 35 mm (1.4 inches) bit if additional holes are necessary.
My advice: first measure the existing hinges and the spacing between the holes very precisely, and then look for suitable soft-close solutions—ideally with user reviews. Soft-close adapters or brackets that mount between the door and hinge are less common and tend to work better with other systems than with KALLAX.
If you have technical data or photos of the current hinges, I’d be happy to assist with measurements or product recommendations.
GUMARTINA
5 Jul 2021 09:18
In short: Yes, individual KALLAX doors can be upgraded to soft-close. You need to replace the existing hinges with soft-close versions, which are available online or at hardware stores.
If the drill holes match, just swap them; otherwise, new holes will need to be drilled. It’s not a big issue, just requires some precise work.
bulanau
6 Jul 2021 11:04
To fully answer the question "Are there ways to convert individual KALLAX doors to soft-close?", I would like to provide a brief how-to guide:
1. Check the construction: KALLAX doors are attached with hinged mounting plates, usually with standard 35 mm (1.4 inch) cup holes.
2. Selecting hinges: When purchasing soft-close hinges, ensure they have the same hole spacing and mounting type (e.g., overlay, half-overlay, or inset).
3. Prepare tools: You will need a Phillips screwdriver and possibly a drill (with a 35 mm (1.4 inch) hole saw) for adjustments.
4. Remove old hinges: Unscrew the old hinges and compare the holes.
5. Adjust the holes: If the new hinges have different dimensions, fill the old holes with wood filler and drill new ones.
6. Install: Carefully screw in the soft-close hinges and adjust the door using the adjustment screws that most of these hinges provide.
7. Test: Open and close the door multiple times until the soft-close mechanism works smoothly.
Note: Soft-close hinges for KALLAX can be found from some furniture hardware manufacturers or on platforms like Amazon and eBay. Pay attention to reviews to avoid hidden issues.
In summary: Retrofitting individual doors is definitely possible but depends heavily on the compatibility of the chosen hinges. Please keep in mind that the door’s stability must be maintained and that adjusting the holes may require extra work.
If you are interested, I can gladly provide links to trusted stores or assist with installation.
