ᐅ Are there ways to adapt Ikea Besta modular units to new needs?
Created on: 10 Jun 2018 13:27
ra_layne
ra_layne
10 Jun 2018 13:27
I would like to start a discussion on the topic: Are there ways to adapt the Ikea Besta modular system to new needs?
Some time ago, I purchased the Besta system to create flexible TV furniture and storage. However, I’m now facing limitations because my requirements have changed — for example, I need more storage space, different compartment sizes, or maybe places for devices that require special ventilation.
Therefore, I’m interested in what specific options exist to retrofit or modify the Besta system without having to buy entirely new elements. Are there proven modifications, rearrangements, additions, or even alternative inserts that you would recommend?
I am also curious about how well the system compatibility really is between the various Besta series and accessories. Are there pitfalls to watch out for?
I look forward to your well-informed experiences and tips on adapting Besta to changing requirements!
sarlo
10 Jun 2018 14:33
Hello ra_layne,
you have asked a very good and important question. The Besta system from Ikea is basically modular and can indeed be adapted to new needs – but of course, there are limits that you should be aware of.
First of all, you can relatively easily modify or replace individual carcasses. Many users, for example, add different doors, shelves, or drawers to increase functionality. Additional trim strips and hanging systems are especially useful for flexible interior organization.
There are also special inserts with ventilation slots available for device compartments, which you can retrofit if you want to house technical equipment.
ra_layne schrieb:
Are there proven modifications, rearrangements, additions, or even alternative inserts that you can recommend?
Answer here: Ikea offers various inserts and organizers as accessories, ranging from shelves and drawers to cable management solutions. You can also adjust the height with furniture legs or improve the appearance with cover panels. Sometimes, a custom modification using standard wood cuttings helps if you are handy with tools.
Just make sure that the fastening system (mostly cam locks) remains intact during any modification, otherwise the stability will suffer.
ra_layne schrieb:
I am also interested in how good the system compatibility between different Besta series or accessories really is.
Compatibility is usually good as long as you stick to the same generation. Older models may have slight dimensional differences, which limits modularity. It is advisable to check exact measurements and connection points carefully before planning.
If you have any further questions, feel free to ask!
landen
10 Jun 2018 16:49
Hey ra_layne,
your question really hits the mark for me! I’ve modified Besta several times, although nothing extremely complicated.
Regarding the modifications, I can say that you can really experiment with various storage components: compartments with doors, open shelves, drawers, or small boxes.
Cable management: there are inserts with openings to prevent devices from looking like a tangle of cables.
Base options: try putting the units on castors to increase mobility.
Even when you join cabinets together, it looks very appealing—almost like custom-made, but much more affordable.
Sometimes it also helps to combine parts from other series with similar dimensions, but be careful, that can get tricky.
All in all, Besta thrives on its flexibility—a bit of tinkering and adjusting is definitely worth it, in my opinion!
V
van_pe
11 Jun 2018 09:02
yes, Besta can be adjusted modularly. You can remove parts, add others, change shelves, or use additional drawer sizes. The system is compatible within the same generation.
Technical appliances can be installed using special inserts with ventilation. Those who are creative also add their own wooden panels or other modifications.
It is important to check the dimensions to avoid problems.
Bautau
11 Jun 2018 12:17
Regarding the Ikea Besta system and the possibilities for modular adjustments to changing needs, there are clear technical and functional facts to consider.
- The Besta system is based on standardized module units with fixed dimensions (mostly 64x38 cm (25x15 inches) footprint). These dimensions are crucial for compatibility and interchangeability.
- Different generations of the system show slight variations in drilling patterns and connection points, so mixing components is not always seamless.
- For expanding storage space or adjusting the interior layout, Ikea offers accessories such as adjustable shelves, drawer inserts, and doors with various opening mechanisms.
- Ventilated inserts are available for electronic devices to prevent overheating.
- Stability is maintained with modular adjustments as long as the original connectors are used and not damaged.
Additionally, customer modifications are possible, such as cutting wood panels for intermediate shelves or using height-adjustable furniture legs, but these require appropriate craftsmanship.
Conclusion: The Besta system offers some modularity options for customization, but users must adhere to the dimensions and system specifications to ensure functionality and stability.
sarlo
12 Jun 2018 08:54
van_pe schrieb:
The important thing is to check measurements to avoid problems.
This is a very important point that I want to emphasize again: Before remodeling or expanding an existing Besta system, you should carefully take all measurements and also verify that the connection points fit correctly.
I also recommend not relying solely on original Ikea replacement parts but experimenting with standard inserts or dimensions if you have specific requirements.
One more tip: If you plan to change the fronts or handles, be sure to check the drilling distances—these are not always the same across all versions.
Do you already have certain changes planned or in mind? Then we can discuss them in more detail.
