ᐅ Are there any upgrades available to improve the stability of IKEA BESTA shelving units?
Created on: 18 Aug 2017 19:12
lakeo
I recently purchased an IKEA Besta shelving system and now I’m wondering if there are any useful upgrades or additions to improve the stability of this system.
My main concern is how to make the shelving unit safer and more load-bearing without significantly altering its appearance or original design. Especially with taller or wider BESTA units, I feel that the stability is not ideal—particularly when loading them with somewhat heavier items.
Are there specific reinforcements, special screws, T-connectors, additional brackets, or perhaps community-developed solutions that have proven effective?
I look forward to your experiences, tips, or any advice on common weak points that can be elegantly addressed with appropriate upgrades.
edisondan
19 Aug 2017 13:03
lakeo schrieb:
How complex is it to replace the back panel without damaging the original condition?
This can be done quite well with some basic craftsmanship. The original back panels are usually just fitted in place and fixed with small nails. These nails can be carefully pulled out without damaging the surface.
The plywood board then needs to be cut to size accordingly (often 6 mm (1/4 inch) thickness is sufficient) and can be secured from the inside with screws. It is important to carefully plan the drill holes before installation and try to place them hidden or on the inside so that nothing is visible afterward.
If you want to keep flexibility, you can also use countersunk screws, allowing you to restore the original condition later if needed. This requires a steady hand and some experience with woodworking.
Penau
19 Aug 2017 13:59
lakeo schrieb:
How complicated is it to replace the back panel without damaging the original condition?
The answer from edisondan is correct. Additionally:
- Any existing plastic strips or tongue-and-groove moldings should be carefully removed.
- Plywood has the advantage of being more dimensionally stable and makes the entire back panel significantly stiffer than hardboard.
- Make sure the panel edges are sanded cleanly to prevent splintering.
- When replacing the back panel, it is often possible to add additional reinforcement brackets or screws on the inside.
It is advisable to take photos before dismantling in case you want to restore the original later.
