ᐅ Are there any upgrades available to improve the stability of IKEA BESTA shelving units?
Created on: 18 Aug 2017 19:12
lakeo
I recently purchased an IKEA Besta shelving system and now I’m wondering if there are any useful upgrades or additions to improve the stability of this system.
My main concern is how to make the shelving unit safer and more load-bearing without significantly altering its appearance or original design. Especially with taller or wider BESTA units, I feel that the stability is not ideal—particularly when loading them with somewhat heavier items.
Are there specific reinforcements, special screws, T-connectors, additional brackets, or perhaps community-developed solutions that have proven effective?
I look forward to your experiences, tips, or any advice on common weak points that can be elegantly addressed with appropriate upgrades.
I reinforced my Besta shelf with additional metal brackets and can only say: great decision! It is now rock solid, and I even put a bit more weight on it than originally planned. This provides so much security that I can highly recommend it to anyone who wants to use their shelf long-term and for heavier loads!
bauku schrieb:
I reinforced my BESTA shelf with additional metal brackets and can only say: great decision!I agree with that. When reinforcing with metal brackets, it’s important to position them at the right points. Especially the connection between the side panel and the bottom panel of the unit benefits significantly, as this area often experiences the highest loads and leverage forces.
Also: are you using self-tapping stainless steel screws? They are more durable and reduce the risk of corrosion. What fastening method are you using on the wall? Did you choose anchors suitable for drywall as well?
Parbo schrieb:
Also: are you using stainless steel self-tapping screws? They are more durable and reduce the risk of corrosion.Yes, exactly! I used galvanized self-tapping screws along with suitable universal wall anchors for the drywall. The anchors are designed to expand behind the wall, providing a secure grip.
For the brackets, I fixed four screws to each shelf — sturdy without being excessive. The sound system has been stable for months, with no wobbling or creaking.
LuMarcel4319 Aug 2017 10:12I would like to make a brief critical comment: Relying solely on metal brackets and especially on fastening to drywall is, in my opinion, not always sufficient. Drywall is inherently not ideal for bearing heavy loads.
From a technical perspective, it is essential to check whether the wall behind the gypsum board has wooden or metal studs and whether these can be reached at specific points. For higher loads, it is advisable to use screw fastenings into these studs, as standard anchors often fail too quickly.
A freestanding shelving unit usually requires additional measures, such as connecting several modules together with strong connectors or installing extra support battens on the back to reinforce the structure.
LuMarcel43 schrieb:
Drywall partitions are inherently not ideal for heavy loads.Interesting point, thank you. I was aware that there are often limits here, but I assumed that the attachment points would ideally hit the studs.
Currently, I plan to mount the shelf using anchors that, according to the description, are also suitable for metal studs. However, I will check the wall beforehand to make sure I actually hit a stud there.
Parbo schrieb:
- Reinforce the back panel with a solid plywood sheet instead of the usual thin hardboard.How complex is it to replace the back panel without damaging the original condition? Has anyone here done this before?
