ᐅ Are there any upgrade options for Ikea Besta hinges to improve functionality and comfort?
Created on: 19 Mar 2023 08:34
norineHello everyone,
I have a rather specific question regarding the Ikea Besta hinges, which are used in many living room shelving systems. I’m interested to know if there are any upgrades or compatible alternatives that can significantly improve the ease of opening and closing.
More specifically: Are there hinges with a smoother closing mechanism, longer durability, or adjustable soft-close features that can be installed in the existing Besta units without major modifications?
I currently have the standard hinges, which work well, but can often be a bit noisy and sometimes stick, especially with frequent use. Perhaps someone has experience with aftermarket solutions or alternative brands that they can recommend to enhance the user experience.
Looking forward to your opinions and tips!
SauDietmar19 Mar 2023 10:47Hello norine,
your question about upgrades for Ikea Besta hinges is absolutely valid, and I can suggest several options to improve ease of use.
First of all: the original Besta hinges are simple cup hinges with soft-closing, but there are some possibilities for improvement.
- Replacement with higher-quality hinges from brands like Blum or Hettich, which often operate more precisely and offer long-lasting adjustable damping. You need to pay attention to the correct drilling pattern and mounting method, as these can sometimes differ slightly with Besta.
- Soft-close retrofit kits: there are universal soft-close modules that can be adapted to the existing Besta hinge fittings. This allows the closing action to become smoother and quieter.
- Adjustment: often, a fine tuning of the existing hinges (usually 3D adjustable) can already improve the movement.
A small tip: when replacing hinges, be aware that new ones may require different drill holes or hinge cups—so taking exact measurements and possibly using installation aids is advisable.
Summary:
- High-quality brand hinges as replacements
- Soft-close modules as add-ons
- Precise adjustment
If you like, I can also provide you with a list of recommended models.
Summary:
SauDietmar schrieb:
The original Besta hinges are basic cup hinges with dampingTo add: Technically, the Besta hinges belong to the budget segment and their installation is designed for standard use. However, there are interesting modifications from third-party manufacturers that offer the following improvements:
- Use of higher-quality materials for the spring and bearing, significantly increasing durability and smooth operation.
- Adjustable damping via screw mechanisms, which are not offered by Ikea originals.
- Soft-close mechanisms that can be retrofitted, but the exact hinge dimensions should be checked to avoid the risk of the door not closing flush.
Regarding installation: Anyone planning upgrades should definitely check the hinge mounting on the cabinet carcass. The Besta front hinges use a special plate whose dimensions do not exactly match the standard of other systems. It is therefore advisable to choose hinges with compatible mounting plates or to modify these yourself.
If you like, I can also provide technical drawings and measurements or advise you on how to precisely check the drilling points.
It would also be helpful to know whether you are looking for more comfort in operation or an improved aesthetic solution, as there are hinges with fully concealed mechanisms that can modernize the overall look.
Gafiel schrieb:
Soft-close mechanisms that can be retrofitted, but you should check the exact hinge dimensions firstI completely agree and would like to add a casual tip: If you want the door not only to close more quietly but also more smoothly, it’s worth taking a look at the small sliders and dampers. Often the devil is in the details, and sometimes simply lubricating the hinges a bit or using a suitable silicone-based lubricant is enough.
I also once tried installing so-called "soft-close adapters" – basically small modules that clip onto the existing hinge. They aren’t cheap, but they’re worth a try if you don’t want to replace the entire hinge mechanism.
A little bonus tip: If you’re up for a DIY approach, you can often find suitable dampers at the hardware store that you can clamp or screw in “between the hinge and the cabinet.” Just be sure to pay attention to the forces and material compatibility, otherwise everything can fall apart after a short time.
Either way – with a little patience, you can get quite a bit more out of the Ikea Besta hinges without having to replace everything right away. Good luck!
