ᐅ Are there any upgrades available for Ikea Besta drawer slides to extend their lifespan?
Created on: 30 Sep 2023 08:42
Kama41
Kama41
30 Sep 2023 08:42
I have a specific question regarding the IKEA Besta furniture series, especially the drawer slides. While the drawer slides basically work, I’ve noticed after some use that they sometimes stick or become difficult to open and close smoothly. So my question is: Are there any upgrades, meaning alternative or improved drawer slides for the IKEA Besta series, that can be used instead of the originals to extend their lifespan or improve functionality?
I’m not looking for general repair instructions, but mainly technical solutions or better replacement parts that are compatible and reduce the usual wear and tear—basically some kind of upgrade kit. If anyone has experience with more durable or specially modified slides for Besta furniture, I would really appreciate any tips or advice.
Thanks in advance!
DULIS
30 Sep 2023 09:17
There are actually no official upgrades from IKEA for the Besta drawers. However, you can replace the standard Tandembox drawers with third-party alternatives, which are often more durable. It is important to check the measurements carefully.
sinhau
30 Sep 2023 11:43
to approach the topic more systematically, here is a brief overview:
1. The original Besta drawer slides are mostly tandem or full-extension slides, either produced by IKEA or supplied by subcontractors.
2. An upgrade usually means switching to higher-quality slides from brands like Blum or Hettich, which operate more smoothly and have longer durability.
3. A practical guide:
- Carefully measure the height, width, and length of your current slide.
- Look for a compatible full-extension slide from a third party (e.g., Blum Tandembox Plus or similar).
- Pay close attention to the installation dimensions and the load capacity of your drawer.
4. During installation, the drawer may need to be adjusted, which is somewhat easier with Besta due to its modular system.
In summary: Upgrades are available, but you must measure accurately to find better running quality and durability with more expensive manufacturers.
Common mistakes when retrofitting include incorrect dimensions or using the wrong mounting hardware, so be careful!
kaubi
30 Sep 2023 14:36
Hello Kama41,
to address your question specifically: yes, there are ways to modify the IKEA Besta drawer slides or replace them with more robust slides designed for longer durability.
Here is what I recommend in detail:
- First, you should definitely check the exact internal dimensions of the drawer (width, height, depth). Besta furniture often varies in side panel thicknesses of 12, 15, or 18 mm (0.5, 0.6, or 0.7 inches).
- The original slides are often simple tandem box systems that can lose smoothness after several years of use, usually due to dirt or lack of lubrication.
- As an upgrade, high-quality full-extension slides from brands like Blum Movento or Hettich Quadro are a good choice, offering significantly higher load capacity and smoother movement.
- A key point is the compatibility of the mounting holes. Sometimes drill holes need to be adjusted, or even individual side panels slightly modified, but this is feasible with a good drill template.
- Alternatively, a complete switch to a soft-close system can help reduce stress when closing, protecting the mechanics.
- For long-lasting maintenance, regularly clean the rails and apply a light lubricant (use a lubricant suitable for metal gliders, avoid too much oil); this greatly extends their service life.
- If you are not very skilled at DIY, a professional carpenter can also assist with installing the right upgrade.
I am happy to answer detailed questions about the specific drawer design if you have the measurements.
How many drawers do you plan to upgrade?
Kama41
30 Sep 2023 15:12
kaubi schrieb:
How many drawers do you want to retrofit?
Thank you for the detailed response, kaubi.
I currently have six drawers equipped with the classic Tandembox system.
My main concern is whether the effort is worth it—that is, whether replacing them with higher-quality slides actually makes a significant difference in durability and ease of use, or if it’s better to simply maintain the original slides well.
Are there reliable experiences or data showing that such a replacement greatly improves longevity, or is the wear from daily use noticeable regardless of the slides used?
lyndon
1 Oct 2023 08:53
Based on my experience, upgrading to high-quality systems from the professional sector can significantly improve both ease of use and durability.
The original IKEA drawer slides are sufficient for normal use, but for heavy use or high loads, branded products like Blum tend to last much longer.
However, as kaubi already mentioned, a perfect fit is crucial. Otherwise, the advantage can quickly be lost due to improperly installed hardware.
Regular maintenance (cleaning, lubrication) also has a major impact on longevity and should not be neglected for either system.
