ᐅ Are there upcycling options for Ikea HEMNES cabinet fronts?
Created on: 5 Jun 2017 14:03
Bentley_pe
Bentley_pe
5 Jun 2017 14:03
Hello everyone, I have a small challenge and am hoping for some creative ideas here: Are there any upcycling possibilities for Ikea Hemnes furniture fronts? Specifically, I’m interested in how to creatively and sustainably reuse these relatively sturdy, painted solid wood fronts instead of throwing them away or simply buying new ones. I would like to know what ideas exist for completely redesigning these fronts—whether in furniture making, decoration, or as practical everyday objects—and which materials or techniques you would recommend. Perhaps you also have experience with sanding and transforming them or with combinations of varnish, paint, and accessories? Thanks in advance for your tips!
pautanner
5 Jun 2017 14:45
Upcycling with Ikea HEMNES fronts sounds like a great project! 😄 The fronts are quite sturdy, which opens up many possibilities. For example, you could convert them into decorative trays by adding handles and reinforcing the back. Or how about custom wall shelves or small pinboards for the office? Adding a bit of paint or special wallpaper as a background can create something truly unique. They also work well as bases for plants or small art panels. A simple tip: sand, mattify, and seal with wax varnish to ensure the surfaces last long-term. 🙂
BLAKEO
5 Jun 2017 15:37
Interesting suggestions, but I wonder how practical the effort for upcycling really is. The HEMNES fronts are coated, which makes sanding difficult, and the material is relatively thin. For which durable everyday items are they actually suitable without losing stability? Is the material value not rather low when considering the costs for paint, sandpaper, tools, and time? Perhaps a better option would be to use the fronts as decorative elements in combination with other materials like metal or thicker wood to ensure durability.
Bentley_pe
5 Jun 2017 16:11
BLAKEO schrieb:
The HEMNES fronts are coated, which makes sanding difficult and the material relatively thin.
That’s a good point I had thought about as well – the finish is quite durable. However, I believe that using a good random orbital sander or sanding pad can gently alter the surface to prepare it for refinishing. You just need to remove a certain percentage of the material and then apply a suitable primer. I find your idea of combining the fronts with other materials very interesting, as it could also compensate for any structural weaknesses.
TEBILO
6 Jun 2017 09:22
I like to approach this topic from a more technical perspective: The HEMNES fronts are usually made of solid wood with a white lacquer finish, typically acrylic based on alkyd. This makes the surface quite durable but also difficult to sand down. For upcycling, the following method is recommended:
- Pretreat with a chemical stripper (to soften the lacquer layer), then dry sand with grit 120 to 180
- If you want to keep the natural wood visible, work with a clear, matte primer between sanding steps
- For a colored finish: acrylic or chalk paints are ideal because they adhere well and are easy to renovate
- Another idea for upcycling is to use the fronts as outer panels for small cabinets, stabilizing the edges with moldings and designing the interior as desired
- Converting them into wall panels is also possible by combining several fronts
It would also be helpful to know how thick your fronts are and whether they have any signs of wear, so the effort can be estimated.
fajan
6 Jun 2017 11:45
I would like to add that the solid wood construction of the HEMNES fronts especially supports many upcycling ideas. Many users repurpose these fronts as clever furniture extensions, for example:
- Furniture rearrangement: using the fronts as doors or cladding elements for unfinished boxes or shelves
- DIY projects: converting them into a magnetic memo board by attaching a metal foil underneath
- Colorful decoration with enamel paints or chalk paints that create a velvety surface
With a bit of patience, it is also possible to round the corners or lightly roughen the edges with sandpaper to achieve a vintage or shabby chic look. I recommend cleaning the fronts thoroughly before starting the transformation.
