ᐅ Are there any upcycling ideas for Ikea Hemnes furniture pieces?
Created on: 12 Jul 2020 19:43
Fomule
Fomule
12 Jul 2020 19:43
Lately, I've been quite interested in upcycling, especially with furniture from the Ikea Hemnes range. I'm curious if there are any specific, creative ideas or proven projects on how to repurpose or redesign individual parts – for example, doors, drawer fronts, or side panels. It’s important to me that the approaches are practical to implement and also provide some functional or aesthetic added value, rather than just being purely decorative experiments.
Who has experience or knows tips and tricks for giving Hemnes furniture parts a second life through upcycling? I'm particularly interested in how to treat the typical wood surfaces without it becoming too complicated, and what kinds of furniture pieces could be created from them. Looking forward to your suggestions!
Scarlett
12 Jul 2020 20:12
I find this question really interesting because Hemnes pieces are often high quality, but their classic design can sometimes feel a bit dull when you try to update them. I’ve personally taken Hemnes cabinets apart and repurposed the doors into small wall shelves by simply painting them and covering the back with decorative fabric. The result was really nice and added a lot more character to my apartment.
That said, I have to admit I experimented quite a bit, and not everything was perfect right away. Sometimes it’s frustrating when the paint doesn’t adhere well or the surface needs a lot of sanding. But I think that’s part of the process, and especially with Ikea furniture made from solid wood, you can create really great things with a bit of patience.
What about you—have you had similar experiences, or does all this seem like too much effort?
NOAHSAU
13 Jul 2020 08:26
I sometimes think the whole upcycling trend for Ikea furniture is a bit overrated. Sure, Hemnes furniture is solidly built, but honestly: turning a simple nightstand into a designer piece? Most of the time, it just ends up as something half-heartedly made that doesn’t really surpass the original Ikea charm.
Scarlett schrieb:
Sometimes it’s frustrating when the paint doesn’t hold properly or the surface requires a lot of sanding.
That’s exactly what I mean! Considering the effort and the result, you might as well buy something a little nicer – or something sustainable that doesn’t have to be rebuilt first.
But if someone enjoys it and uses upcycling as a creative hobby, why not. I just think people shouldn’t expect too much from the “magical” transformations.
nonere
13 Jul 2020 13:59
Regarding the situation: Hemnes furniture is usually made of solid wood or engineered wood with a thin plywood veneer and is designed for long-term use. This results in the following practical upcycling options:
- Removing and sanding off the surface finish to highlight the natural wood grain.
- Repainting or staining the piece to give it a fresh, personalized look.
- Repurposing drawer fronts into wall panels, organizers, or decorative elements using mounts.
- Using the side panels as shelves or as a base for small seating with upholstered cushions.
- Combining with metal or leather accents for a modern mixed-material design.
These methods are well-documented and require a moderate level of craftsmanship. For optimal results, thorough sanding and appropriate primers should be applied to avoid issues with adhesion of the new surface. This can significantly extend the lifespan of the refurbished item.
Lilygla
14 Jul 2020 10:37
I would like to elaborate in more detail on the technical aspects that are really important when upcycling Ikea Hemnes pieces:
1. Material analysis: Hemnes furniture is usually solid pine wood, sometimes with plywood back panels. This is generally good for sanding work, but the surface often has a thin layer of lacquer or oil that needs to be removed before applying a new coating. This is usually done with 120 to 180 grit sandpaper.
2. Surface preparation: Depending on the existing finish, it is advisable to start with a coarse sanding and then smooth the surface finely. If using a stain, be sure to test it first on an inconspicuous area to see how the wood reacts.
3. Resealing: For furniture subject to heavy use (e.g., tables or shelves), it is recommended to apply a clear lacquer or hard wax oil after the paint or stain layer. This protects against moisture and wear.
4. Assembly and functionality: For example, when transforming doors into sideboards, consider how hinges or handles can be reused effectively. It is often a good idea to use firmly screwed joints to ensure stability.
5. Ideas for reuse:
- Drawer fronts as small magnetic boards or hook rails
- Doors as upholstered headboards for beds
- Sideboards converted into accessible seating
Finally, a question for you: What is most important to you in upcycling projects? Should the focus be more on design or on functionality? This can greatly influence the approach.
