ᐅ Are there upcycling alternatives for Ikea HEMNES furniture?
Created on: 8 Jan 2022 11:23
Erez10
Erez10
8 Jan 2022 11:23
Lately, I have been thinking a lot about sustainability, especially about upcycling as a way to extend the life of established furniture and give it a new look. In this context, I came across the Ikea Hemnes series, which is actually quite sturdy and affordable. My specific question is: Are there proven and practical upcycling alternatives for Ikea HEMNES furniture that allow you to enhance or redesign the pieces without completely disassembling or replacing them?
I am particularly interested in methods that don’t require extensive prior experience with DIY or craftsmanship but still deliver good results. Which materials, techniques, or ideas have you personally tried or can recommend?
I would really appreciate tips on tools, painting techniques, furniture films, or creative changes like new handles or combinations with other materials. Thanks in advance!
semuneo
8 Jan 2022 13:57
Hello Erez10,
you’re bringing up a really interesting topic. I think it’s great that you’re thinking about sustainability and looking for upcycling alternatives specifically for Ikea HEMNES furniture. I’ve noticed that many people hesitate with these kinds of pieces because they’re worried about the amount of work involved, which I completely understand.
What helped me personally was not to completely alter the furniture but to start small, for example with new handles or a layer of chalk paint that enhances the vintage look. Sometimes it’s more about the atmosphere you create with simple methods. For instance, I had a dresser that I decorated a bit with stencils – it was very well received and turned out to be easier than expected.
To answer your question: wood care products like waxes, oils, or even simple sanding before painting often make a big difference. Applying adhesive films is also a practical alternative if you prefer to avoid experimenting too much with paint.
Do you have specific HEMNES pieces you want to modify? Sometimes it makes a big difference whether it’s wardrobes, dressers, or tables.
SauDietmar
8 Jan 2022 16:02
Hello Erez10,
I would like to provide a structured overview here, as your question covers many aspects that I would like to clarify more precisely. In general, upcycling Ikea HEMNES furniture is quite feasible, especially since the pieces are usually made from solid pine or other machine-processed woods. Here are my suggestions, which have proven effective and manageable:
- Preparation: Sanding is the most important step for better adhesion of paints or stains later on. It is best to use sandpaper with a grit between 120-180.
- Painting techniques: Chalk paint is popular because it can be applied without a primer. Alternatively, wood stains work well if you want to preserve the wood grain.
- Replacing handles: New metal handles or vintage ceramic handles can be relatively easily swapped using the existing drill holes.
- Veneering: Furniture films with wood or marble designs can be applied but require a clean, smooth surface.
- Additional details: Applications such as wooden ornaments or wallpaper scraps can be attached to the back panel to create an interesting contrast.
Common mistakes I have seen:
- Insufficient sanding before painting, which causes adhesion problems.
- Not allowing the paint to dry fully between coats.
- Incorrect handling of holes or screws – therefore: remove all screws and fill the holes when installing new handles.
The most important advice at the end: Allow yourself enough time, as quick changes rarely achieve the desired effect.
If you need more detailed tips on individual steps, I am happy to help.
semuneo
9 Jan 2022 09:46
I completely agree with you; chalk paint really has a significant impact on the atmosphere of the piece of furniture, and you don’t need much experience to use it effectively.
In addition, I would suggest checking out your local hardware store or craft shop during weekdays to find some unique, small handles – this way, the furniture gains a new personality without much effort.
For me, another interesting approach was covering a HEMNES dresser with veneer foil and then applying a clear lacquer. This has the advantage that the original wood grain remains visible, but the furniture takes on a completely different character that looks more refined.
Of course, this is an alternative that requires more time, especially due to the careful application and bubble-free installation of the foil, but the result is worth it.
What about you? Do you already have a project in mind with a specific piece of furniture?
