ᐅ Are there any clever tips for reinforcing KALLAX units after moving them?
Created on: 8 Aug 2021 10:37
nigikin
Are there any clever tips for reinforcing KALLAX after moving? I have often noticed that the shelves lose stability after being taken apart and reassembled, even when all parts are correctly installed. Especially when setting up the KALLAX in a new apartment or room, the structure seems less sturdy than before. Are there any practical suggestions beyond the standard instructions to make the shelving more durable and secure? I would appreciate any advice based on personal experience or professional knowledge!
Don’t get me wrong, but I know the problem with moving very well. Every time after assembling, I get a bad feeling that the shelf will soon give way. My solution was to reduce the load and store heavy items differently.
Still, I find the tips here really helpful. I’m also wondering: Are there ways to maintain the material itself so the wood stays stable? Maybe treatment with furniture oil or something similar? I’m a bit unsure whether that helps with IKEA chipboard.
RonJarrett9 Aug 2021 09:50Elias schrieb:
Are there methods to maintain the material yourself so that the wood stays stable? The shelf is mainly made of particleboard with a melamine coating. Treating it with furniture oil usually won’t penetrate the surface and can cause stains. It is better to avoid moisture and repair minor scratches with appropriate repair kits.
For stability after moving, the connection points are crucial – this is where you should focus your attention.
Thank you for the many suggestions! To summarize, my approaches are as follows: waxing the plug-in connections, using invisible metal clips, adding wood glue, possibly double-sided tape to reduce play, and careful handling of weight.
I would also like to know: Is there anything you would definitely avoid because it could damage the KALLAX or make it permanently unstable? For example, overtightening screws or drilling into the board?
I want to avoid unnecessary risks, thank you!
