ᐅ Are there any tips for successfully remodeling Ikea Metod kitchens?
Created on: 16 Jan 2021 08:37
JANDANTEHello everyone,
I am currently planning to retrofit my Ikea Metod kitchen and am looking for specific tips and best practices to ensure the project is successful. I am especially interested in how to carry out the removal and installation efficiently without causing any damage, as well as which tools or aids are particularly recommended.
Are there any tips for adjusting the dimensions or solutions to adapt existing modules to new requirements or room layouts? Additionally, I would appreciate advice on how to customize the otherwise standardized cabinet configurations in a meaningful way without compromising the kitchen’s stability.
Who has experience with retrofitting Metod kitchens and can share practical insights?
Thank you in advance for detailed responses!
edisondan16 Jan 2021 09:11Hello JANDANTE,
For a successful conversion of Ikea Metod kitchens, the following points are essential:
- Before starting the work, make sure to have the existing plans or a precise survey of the kitchen.
- Handle the removal of modules carefully to avoid damaging the carcasses and fronts – a putty knife and screwdrivers with well-fitting profiles are helpful here.
- Measurements should be taken with millimeter accuracy, as the Metod carcass uses modular standard sizes, but minor adjustments are often necessary.
- For adjusting dimensions, specialized hole saws for wood or jigsaws with fine-toothed blades are recommended, as they allow especially clean cuts.
- Always keep screws and fastening materials well organized and watch for reuse possibilities.
- Stability is maintained as long as the original fastening points are not altered – for custom adjustments, the use of metal brackets or additional connectors is advisable.
Tools such as a cordless drill with torque control and protective gloves are mandatory during the conversion.
In general: Plan carefully and stay calm. This helps to avoid mistakes.
edisondan schrieb:
Measurements should be taken with millimeter precision because the Metod cabinet system uses modular standard dimensions, but minor adjustments are often necessary.This is a very important point that I would like to elaborate on:
The Metod kitchen system is primarily based on a modular grid of 20 cm (8 inches) width per cabinet frame. This means that most fronts and cabinet widths can be divided according to this grid. Any modifications – for example, replacing cabinet doors or fitting special appliances – require understanding the grid and making fine adjustments as needed.
Here are the steps I recommend for modifications:
- Step 1: Accurately measure all relevant room dimensions, including wall irregularities or protruding pipes.
- Step 2: Select modules based on the grid principle and consider what adjustments are necessary – for example, trimming fronts or using panels matching the module width.
- Step 3: For cutouts (e.g., for installing a faucet or appliance connections), use a router with a guide plate to achieve precision.
- Step 4: When modifying individual drawers or inner pull-outs, pay attention to special Metod rails, since some pull-outs are only compatible with certain cabinet depths.
- Step 5: To ensure stability, never countersink screws into the edge holes of the cabinet frame; always use the designated fastening points.
Additionally, it is advisable to create a detailed building plan with measurements before starting modifications and preferably schedule multiple work stages to avoid stress.
I would be interested to know what stage you are currently at and exactly what needs to be modified?
Le_kin schrieb:
I’m curious at what stage you are currently and what exactly is going to be converted?Good question. I have had the kitchen for several years and mainly want to address the following points:
- Replacing some base cabinets with wider drawer units.
- Installing a new induction cooktop with built-in downdraft ventilation, which requires modifying the countertop and cabinet configuration.
- Adding extra power outlets in the kickboard/toe-kick area for more convenience.
The kitchen is already installed, so it’s more about targeted modifications rather than a complete rebuild. I want to avoid causing unnecessary damage or material loss through incorrect procedures.
Therefore, besides tool recommendations and measurement tips, I am also interested in experiences with the connection details—especially regarding the adjustment of the countertop for this cooktop with integrated ventilation.
I would appreciate practical advice on this aspect.
JANDANTE schrieb:
I would appreciate it if someone could provide practical advice on this aspect.Regarding a new countertop and cooktop with integrated downdraft ventilation:
- When cutting the opening for the induction cooktop with downdraft extractor, use a router for clean and precise edges to avoid later leaks or unnecessary material loss.
- Make sure the countertop is thick and stable enough; in Metod kitchens, the original countertops are often 28 mm (1.1 inches) thick – but 40 mm (1.6 inches) is better if improved insulation and stability are needed.
- The connection for the downdraft extractor requires a special ventilation system or at least a well-ventilated interior space. You must carefully plan the airflow path during the retrofit.
- Cables and water connections for the cooktop should be properly routed and remain flexible before final installation.
- When replacing cabinets with wider drawer modules, temporarily removing the countertop is recommended to create more working space.
These tips are especially useful if you want to adapt to existing dimensions and interfaces rather than fully redesign the layout.
KAMERON schrieb:
When cutting out the space for the induction cooktop with an integrated downdraft extractor, it is recommended to use a routerI would like to add that using a router with a guide bushing or a guide rail significantly improves not only precision but also safety. This is especially important for often lacquered or coated countertops, as it helps prevent unsightly chipping.
Another point is the decoupling of the downdraft extractor from the cabinet: otherwise, vibrations can be transmitted to the cabinets, causing increased noise. Thus, technical aspects of construction and sound insulation come together here.
Regarding the electrical connections: make sure there is enough slack in the cables, because during modifications you should always anticipate the possibility that wiring inside the cabinet may need to be rerouted.
Does your project possibly involve any changes to the hot water/drain connections, or is it limited to electrical and mechanical work on the cabinets?
