ᐅ Are there any tips for ensuring smooth and quiet door movements with Billy?
Created on: 19 Nov 2022 08:27
marsel60
Good morning everyone,
I have a Billy bookshelf from Ikea in my apartment, and I’ve noticed that the doors, especially when moved frequently, tend to be quite noisy and sometimes a bit stiff. I’m very interested to know if anyone has tips or proven methods to make the door movements on the Billy as quiet and smooth as possible.
I’m thinking about possible adjustments to the hinges, lubricants, or other technical tricks. Maybe there are specific replacement parts for the doors that could improve opening and closing.
I would appreciate any helpful advice, especially if it can be done without major modifications. Thanks in advance!
marsel60
19 Nov 2022 12:01
Genevieve schrieb:
Could you describe exactly where the sticking occurs, whether at the hinge or on the door itself?
Thanks for asking! I mainly notice the sticking at the hinges themselves, and when closing, there is often a slight squeaking or creaking sound. The doors are not warped; I have checked that. It sometimes feels like the metal parts inside the hinge are rubbing against each other very slightly.
olivernu schrieb:
If the doors do stick, it can also be due to a slight warping of the door. Sometimes tightening the hinge screws or making small adjustments helps.
I will try adjusting the screws then.
Does anyone have experience with lubricating the original hinges? Or is the effect usually limited?
Hector
19 Nov 2022 12:47
marsel60 schrieb:
Is there any experience with whether the original hinges can be properly lubricated?
I doubt that lubricants alone will provide a lasting solution if the hinges were not designed for durability from the start. Such hinges are often intended for inexpensive furniture and tend to show wear over time.
Alternatively, it might be worth considering an investment in high-quality hinges, especially if you value quiet and smooth closing in the medium term.
Genevieve
19 Nov 2022 13:23
I would like to add that it is quite common to replace the hinges in IKEA furniture like Billy with better-quality models. There are also soft-close mechanisms available that can be relatively easily retrofitted, allowing for a gentle closing.
Hector schrieb:
Alternatively, one might consider whether investing in high-quality hinges is a more sensible option in the medium term
I agree – sometimes what is offered is not a long-term solution. Marsel60, is this an option for you?
marsel60
19 Nov 2022 14:06
Hector schrieb:
Alternatively, one could consider whether investing in high-quality hinges might be more sensible in the medium term
That’s a good point. However, I find it a bit disappointing that the original hinges start to cause problems relatively quickly.
Genevieve schrieb:
Are there also damper mechanisms that are relatively easy to retrofit?
Could you provide more specific product recommendations? I want to first check if it is technically compatible with my Billy shelf before investing a lot of money.
O
olivernu
19 Nov 2022 15:42
Some users report that these 'soft-close' retrofit kits, which can be attached to standard hinges, generally work well. However, some basic DIY skills are required, as the mounting is not always perfectly suited for Billy units.
If you want to avoid major modifications, it’s best to start with lubricants and adjustments, as this is often sufficient. If not, replacing the hinges is the only option.
derrick34
20 Nov 2022 07:44
Regarding the soft-close retrofit kits: I installed one myself. I had to modify the shelf slightly because the mounting was different. But it’s worth it, as the noise is eliminated and the door closes gently.
