ᐅ Are there any tips for assembling Malm furniture with limited tools?
Created on: 28 Oct 2016 18:13
narhorst
Hello everyone, I would like to ask for your advice on the topic “Are there any tips for assembling Malm furniture with limited tools?”.
I want to build a small Malm shelf myself but have very limited tools – basically only a handsaw, a hammer, some nails, and a drill with a basic set of drill bits. I don’t have access to larger machines like a table saw or a router.
My specific question is: How can I assemble Malm furniture pieces as precisely and securely as possible using just these basic tools? Does anyone know simple techniques or tricks to improve the joints between the panels?
I’m also interested in any special tips for getting clean edges or possible alternatives if certain tools are missing.
I look forward to your ideas and experiences – thanks in advance!
leson
29 Oct 2016 09:11
If you don’t have clamps available, improvised ratchet straps will also work. They provide enough pressure on the glued joint.
giabau
29 Oct 2016 10:22
narhorst schrieb:
Is there a good trick to cut edges fairly straight and clean with a handsaw without it slipping?
Sure, a little trick I often use: Use an adjustable miter guide board clamped to the workpiece. This way, you can guide the saw with a solid, steady reference.
If you don’t have a special guide board, a straight batten placed against your cutting line works as well. The key is really securing it firmly; otherwise, it tends to slip easily.
One more tip: Sawing should be done with full concentration and smooth, continuous strokes—rather even and steady rather than with a lot of force.
narhorst
29 Oct 2016 16:03
Ramon4 schrieb:
Dowels increase stability, even though doing so without special tools is more difficult.
Thanks for the tip about dowels!
I wonder if it’s possible to do this yourself using a thin metal rod and a good eye for accuracy to pre-drill dowel holes? Or do they really require the precision that only special drill bits can provide?
Are there any alternatives to dowels that can be installed with minimal tools?
eldubi
30 Oct 2016 07:52
I can only agree with what has already been said: glue and nails are great, and pre-drilling is essential.
For dowels, there are simple methods: small wooden strips or even toothpick-thick wooden sticks can be used as "replacement dowels" in pre-drilled holes, which also increases stability and is straightforward.
When it comes to sawing: if you’re not very precise, I recommend leaving the cut edge slightly wider and then smoothing it with sandpaper or a sanding block.
This gives you a bit more leeway, and the shelf result will be cleaner.
barEsperan
30 Oct 2016 09:14
A handy tip when you have limited tools: use multipurpose corner brackets from the hardware store to reinforce corners.
They are inexpensive, easy to screw in, and significantly improve stability.
leteo
30 Oct 2016 11:43
Hello narhorst!
I find this topic really interesting and have built with minimal tools myself. One tip that maybe hasn’t been mentioned yet: If you make a kind of “template” from thin plywood, you can guide the handsaw along it – this prevents slipping and helps achieve straight cuts.
Even though it takes longer without power tools, it’s enjoyable and with some practice, you can get very good at it.
Oh, and my advice: take your time, approach the project calmly, and remember that small mistakes hardly show once the piece of furniture is finished :-) Good luck!
