ᐅ Are there suitable gliders or sliders for heavy KALLAX units on tile floors?
Created on: 27 Apr 2022 09:17
fugencay3
fugencay3
27 Apr 2022 09:17
I plan to place some of my KALLAX units, which are mainly loaded with heavy contents, on a tiled floor. I’m wondering if there are appropriate glides or protective devices that help move the units without scratching the floor while also supporting the weight. I am particularly interested in models or solutions designed specifically for heavy loads, as some regular felt pads have worn out quickly or even slipped in my experience.
Does anyone have experience with suitable glides that are sturdy enough and stay in place on tiled floors? Are there perhaps combinations of glides or self-adhesive products that have proven reliable? Any tips on what to look for when purchasing would be appreciated. I would be grateful for any specific product recommendations or personal experiences!
retau
27 Apr 2022 10:03
Oh yes, this topic is very important! :-) I recently solved this at my home by using special furniture glides made of Teflon – they are really durable and slide smoothly on tile floors. It’s important that they can withstand the maximum weight, otherwise problems arise quickly.
The best are models with a metal base that can be firmly attached to the furniture, not just glued on. This holds much better in the long run! The investment is worth it, as no more scratches on the tile floor is fantastic!
So, feel free to search for "furniture glides Teflon metal." That’s what I use and it works great! Good luck 🙂
Landontau
27 Apr 2022 11:46
In brief: For heavy KALLAX units on tile floors, choosing the right glide is essential, as retau has already mentioned.
Here is a brief overview of the approach:
1. Check load capacity: Look at the maximum weight the glide can support.
2. Consider material: Teflon (PTFE) glides are excellent for hard floors.
3. Attachment: Screw-on or nail-on glides are often more stable than adhesive ones.
Common mistakes include buying felt glides, which wear out quickly, or neglecting the weight class.
Conclusion: For heavy units, it is better to choose metal-Teflon combinations. If using adhesive products, only select those that explicitly state high load capacity. Good luck with testing!
ANMARCOS
28 Apr 2022 08:22
retau schrieb:
The best models are those with a metal base that can be firmly attached to the furniture, not just stuck on.
I find this opinion a bit one-sided. Sure, screw-on glides are sturdy, but who wants to drill into Ikea furniture? Especially with KALLAX, that’s often not an option.
Why not consider high-quality, thick felt glides with a special adhesive backing? They do wear down, but can be replaced quickly and without tools – and they preserve the appearance of the furniture.
Also, glides matter less on tile floors if the weight is distributed evenly. Simply placing wooden or plastic boards underneath can have a big effect – also preventing scratches and pressure marks.
JONSON
28 Apr 2022 09:01
ANMARCOS makes an important point: For heavy KALLAX units, it is worth considering an overall solution for floor protection.
A practical and proven method is to place furniture protectors made of plastic or MDF under the units and attach suitable felt glides or Teflon glides to them. This way, the weight is better distributed, and the risk of scratches on tiles is directly minimized.
The combination of load distribution and smooth gliding is crucial. Adhesive glides alone can sometimes fail, especially under heavy loads.
Ethan
28 Apr 2022 11:33
Hello!
I would like to add that the size of the gliders is also crucial when choosing them. Larger gliders with a bigger contact area distribute the weight better and protect the floor more effectively.
Also, make sure to carefully read the manufacturer's specifications regarding the weight capacity, which is often underestimated.
If possible, test different types of gliders first in a less visible spot to see how they perform on your tiled floor.
If you are unsure, it’s better to choose models rated for higher loads. Additionally, combinations with protective mats are an option if the gliders alone are not sufficient. I wish you good luck optimizing your KALLAX!
