ᐅ Are there digital water meters available?
Created on: 18 Feb 2026 09:31
HilfeHilfe
HilfeHilfe
18 Feb 2026 09:31
we have two units. The utility room contains the main meter from the local utility company, and each unit has its own separate analog water meter to measure water consumption individually.
We would like to replace the meters in both units. Is there a recommendation for installing digital water meters that can be read via an app? We do not want to use a service provider like Ista or Techem, as we manage everything ourselves.
Mahri2318 Feb 2026 10:32
Hi,
I believe the water meters are always supplied by the provider. They are "calibrated" and replaced every 7 years anyway.
nordanney
18 Feb 2026 12:40
HilfeHilfe schrieb:
Is there a recommendation here to install a digital water meter and read it via an app?
No, there isn’t a specific recommendation. However, there are various suppliers of suitable devices (ultrasonic water meters) – as far as I know, only for cold water and mostly intended for larger consumers. These devices usually operate via wireless communication and/or can be integrated into reading systems used by meter reading companies. For private use, you would probably need to do some DIY work.
Additionally, these devices tend to be quite expensive.
Jesse Custer
18 Feb 2026 13:40
I only know the GROHE Sense Guard in digital form.
It also includes a monitoring unit for water pipe bursts or similar issues.
However, without installation, it costs around 1,000 euros.
RotorMotor
18 Feb 2026 21:01
I have a cyble sensor installed on our meter by the utility company.
