Hello everyone, I am planning to get an Ikea Platsa system for my living room and am currently researching the best storage solutions for the individual modules. My specific question is: Are there storage boxes that are dimensionally and aesthetically designed to fit perfectly into the Ikea Platsa compartments—ideally without needing additional dividers or modifications? It is also important to me that the boxes are sturdy, easy to handle, and preferably available in various sizes to allow flexibility in storage. Perhaps someone here already has practical experience or specific recommendations on brands or products that work especially well with the Platsa system. Thanks in advance for your support!
kesau schrieb:
Are there storage boxes that are dimensioned and designed to fit perfectly into the compartments of the Ikea Platsa system—ideally without needing additional dividers or modifications?As far as I know, there are no storage boxes officially certified by Ikea specifically for the Platsa system. However, the internal dimensions of each module are clearly defined, which makes the search easier. Boxes with the following dimensions fit best:
- Width and height depending on compartment depth, usually 33 x 33 cm (13 x 13 inches) for square units
- Depth variable, often between 40 and 50 cm (16 and 20 inches)
I recommend boxes from brands like Elfa or mDesign, as they are easy to combine and provide good stability when the measurements match. Boxes with smooth edges and stackability work especially well for Platsa. Be cautious with cheap products from discount stores, as the fit often isn’t quite right. Investing in boxes with built-in handle cutouts also significantly improves usability.
kesau schrieb:
Are there storage boxes that match the dimensions and design of Ikea Platsa so well that they fit perfectly into its compartments—ideally without me having to add dividers or make adjustments?Hello, I’d like to provide a brief guide on how to find suitable boxes for Platsa and what to keep in mind:
1. Measure precisely: Ikea provides the external and internal dimensions of the Platsa modules, but double-check by measuring yourself as slight variations can occur.
2. Choose the material: Plastic boxes offer stability and are easy to clean, while fabric boxes look nice but often lose their shape over time.
3. Check the fit: Boxes should fit snugly without too much play, otherwise they might slip when pulling out or shift when pushing in.
4. Handles: Sturdy and easy-to-grip handles are important, especially for heavier contents.
5. Modularity: Vary box sizes to organize different items effectively (e.g., small boxes for accessories, larger ones for clothing).
6. Manufacturer: Ikea does not have a universal box for Platsa, but the storage series "Kuggis" fits most compartments with 33x33cm (13x13 inches) well, although the depth may vary.
Summary: Perfect boxes without any adjustments are rare, but with some time spent on measuring and selection, you can find very well-fitting storage boxes that complement the system perfectly.
Joshbe schrieb:
Be careful with cheap products from discount stores, the fit is often not right.Exactly, that’s why it’s better to go for branded products or check directly at Ikea. The "Kuggis" boxes are well suited for Platsa modules, especially for 33cm x 33cm (13 inches x 13 inches) compartments.
KUDAISY schrieb:
The boxes should fit snugly without much play; otherwise, they may slide out when pulled or shift when inserted.This is a very important point. In my experience, it makes sense to determine the exact internal dimensions of the specific Platsa model, as the modules can vary slightly in depth and internal height.
I also recommend boxes that are semi-transparent or have a lid, so that the contents are easily visible while also being protected from dust. This combines functionality with a tidy appearance.
For those who prefer a more customized option, boxes with removable dividers can be useful, especially for storing a variety of items.
In summary, the selection criteria should include not only fit but also durability, comfortable handles, and aesthetic matching to ensure storage remains convenient and efficient over time.
