ᐅ Are there specific screws that provide greater stability for BILLY shelves?
Created on: 12 Mar 2022 08:47
pimeo
I am currently looking into the stability of Billy shelves, especially concerning the screws used. Are there specific screws or types of screws that can be used instead of the original ones to significantly improve the stability and load-bearing capacity of the shelves?
My main focus is whether this can make the shelf more resistant to stress or twisting without the need for additional reinforcements or modifications.
I would appreciate advice on suitable screw types, dimensions, materials, and any experiences with alternatives that have proven effective.
Wow, that makes perfect sense! I’m really motivated now to upgrade my BILLY shelf 😄💪.
One more question: Are there screws you can get directly at a hardware store that are especially recommended? Or is it better to go for special orders, like stainless steel screws or ones with rust protection coating?
Good question!
Here is a brief guide to help you find the right screws:
1. Type: Particleboard screws (due to the material of the BILLY shelves)
2. Length: at least 30–40 mm (1.2–1.6 inches) to ensure proper holding strength
3. Diameter: 3.5 to 4 mm (0.14–0.16 inches) is ideal; thicker screws often make a difference
4. Material: galvanized or stainless steel screws are more durable
5. Head: countersunk or pan head, matching the mounting surfaces of the shelves
In summary: You can find most of these screws as standard items at hardware stores. If needed, you can order more specific versions online, for example, fine-thread screws for an especially secure hold.
I know the feeling that everything always feels shaky and unstable. I can only confirm that switching to stronger screws really makes a difference.
What helped me the most was to never tighten the screws too much or leave them too loose – otherwise, the material quickly gives way.
I also think it’s important to emphasize this – sometimes you need to make small repairs to the wood or fasten the shelves differently.
sonplo schrieb:
Even the best screws won’t help if the chipboard is too thin or porous.
In conclusion, a summary and a tip: For better stability with BILLY shelves, chipboard screws with a 4 mm (5/32 inch) diameter and at least 40 mm (1 5/8 inch) length made of galvanized or stainless steel are especially suitable. Countersunk heads help to recess the screw heads flush and distribute the load evenly.
Furthermore, the installation of the screws is important: a clean pilot hole, matched to the screw diameter, prevents splitting and improves holding strength.
Optional reinforcements with metal brackets or wooden strips are a practical addition for heavy loads.
By the way, that’s exactly the right perspective for a stable solution!
retau schrieb:
Ich hab jetzt richtig Lust, mein BILLY-Regal aufzupimpen 😄💪
