ᐅ Are there specific screws for Malm dressers?
Created on: 24 Feb 2023 18:23
todaflo
todaflo
24 Feb 2023 18:23
Hello everyone, I have a specific question regarding the popular Ikea Malm chest of drawers: Are there any special screws or fasteners that are specifically made or recommended for Malm chests? I’m not just referring to the screws that come standard with the product, but whether there are Malm-specific screws available as replacement parts or for extensions, which differ in material, size, or thread type. The reason is that I need to replace some screws on an older Malm chest and I’m not sure if I can use standard screws from a hardware store or if that might affect the stability or material of the chest. Does anyone have experience with this or any advice on exactly which screws are used for Malm? Thanks in advance for your input!
bauku
24 Feb 2023 19:07
It’s really great that you’re paying such close attention to the screws for the Malm chest of drawers! 🙂 From experience, I can tell you that Ikea sometimes uses special screws, especially for the Malm series. The screws are often custom-made, for example, they may have a special coating or be made from durable material to ensure the chest remains stable.
todaflo schrieb:
if there are Malm-specific screws for replacement parts or extensions
Exactly, those do exist! You can even order replacement screws from Ikea designed specifically for your Malm chest of drawers. It’s worth being cautious and not using standard screws from a hardware store. If you need the right screws, either check Ikea’s replacement parts online or ask at your nearest Ikea store!
Good luck with your project, it’ll surely turn out great! 🙂
Ianlau
25 Feb 2023 07:56
Good morning, todaflo! Your question is very precise, which greatly helps in providing an accurate answer.
To address your uncertainty: Ikea uses different types of screws for the Malm furniture series, designed as part of a modular system tailored to the furniture. These are meant to distribute loads effectively and ensure a durable connection. They are not always standard wood screws but often include cam locks, dowels, and eccentric connectors.
todaflo schrieb:
I am not sure if I can use regular screws from a hardware store or if that might affect the stability
Generally, standard screws from a hardware store may have similar dimensions, but the thread type, length, and hardness can be critical. A DIY replacement from a hardware store might work, but the fit and quality matching the original parts are most reliably found with genuine replacement components. Additionally, the advantage of original parts is that the material thickness and coating are precisely matched to the wood and the expected load, which helps prevent long-term damage.
My advice: On the Ikea website, search under "replacement parts" using the model number of your Malm dresser. There you can order the exact screws and connectors used in your dresser. If you are planning any modifications, it is especially important to use the correct connectors to ensure stability.
bupar
25 Feb 2023 10:42
The question of special screws for Malm dressers is technically relevant because the furniture design relies on modular connections. Ikea uses, among others, so-called cam screws, which, together with cam connectors, provide a stable click system. These screws differ significantly in material and shape from standard wood screws.
bauku schrieb:
Ikea uses special screws, especially for the Malm series
These special fasteners ensure both strength and easy assembly and disassembly. For replacement or repair, original parts are strongly recommended because alternative screws often do not fit precisely or may damage the material.
Anyone opting for standard hardware store screws should pay attention to dimensions, thread type (fine thread vs. coarse thread), and strength class. An unsuitable screw can force the material apart or negatively affect load-bearing capacity.
Conclusion: For the best results and long-lasting stability, Malm-specific screws are recommended, which Ikea also offers as replacement parts.
Luchen
26 Feb 2023 09:13
There are special screws for Malm dressers, especially cam screws.
I would always use Ikea replacement parts because they fit perfectly and are sturdy.
Ianlau
26 Feb 2023 12:35
Exactly, the cam screws are key to the stability of the Malm dresser. They allow a secure connection without the need to clean screws during assembly. This also prevents damage to the wood from overtightening.
If replacement parts are needed, Ikea provides suitable kits, even for older models.
I would avoid using cheaper screws from hardware stores because, with furniture like the Malm dresser, even small details can affect the lifespan.
