ᐅ Are there special protective films available for Ikea BESTA surfaces?
Created on: 1 Apr 2024 10:23
yaminfloHello everyone,
I am currently planning to make my Ikea Besta furniture more durable and am wondering if there are special protective films designed specifically for the surfaces of this series. My main goals are to prevent scratches, stains, and minor impacts without significantly changing the appearance or feel.
I am particularly interested in whether there are films tailored to the material composition and surface of Besta, as I have heard that some protective films can cause damage to coatings due to chemical reactions or poor adhesion.
Has anyone had experience with special protective films for Besta furniture or alternative recommendations that provide effective protection while remaining visually discreet? I look forward to your tips and advice, including assessments of durability and practicality.
The Ikea BESTA series typically features a melamine resin-coated surface that is relatively durable but not completely scratch-resistant. Due to the surface properties, there is no original manufacturer-specific protective film from Ikea.
Commonly available are PVC or TPU-based adhesive films, which are used universally for furniture. For BESTA, however, it is important to choose films that allow good air circulation beneath the adhesive to prevent peeling and damage.
Additionally, matte, transparent protective films are recommended as they do not cause a glossy distortion of the surface. Another consideration is the expected level of wear: thicker films with high scratch resistance are suitable for heavy use, while thin films are sufficient for light protection against dust and minor scratches.
Alternatively, I also recommend surface sealants or waxes specifically designed for coated furniture. These provide protection as well, without leaving adhesive residues.
usbla schrieb:
Commonly used are PVC- or TPU-based adhesive films, which are widely used for furniture.Exactly, such universal films work well. It is best to thoroughly clean the surface before application, so the film adheres better and lasts longer.
yaminflo schrieb:
Does anyone have experience with special protective films for BESTA furniture or alternative recommendations?I haven’t found a film solution specifically for Ikea BESTA, but I currently use self-adhesive transparent films designed for furniture and floor protection. I cut them to fit precisely. It’s important to choose films that can be removed without leaving residue and do not react with the surface.
Sometimes it helps to apply protection only to high-wear areas, such as cutouts or edges. I always make sure to apply the film slowly and bubble-free at room temperature.
If you like, I can provide the name of a manufacturer or supplier I have had good experience with. Alternatives include protective sprays or sealants if you prefer not to have a visible film.
