ᐅ Are there any specific cleaners recommended for Ikea Brimnes furniture?
Created on: 30 May 2024 08:17
goneo46Hello everyone,
I recently purchased an Ikea Brimnes bedroom furniture set and am now looking for suitable cleaners that protect the surface of the material and ensure its long-lasting durability. The Brimnes series is known for its coated wood-based panels, which can be sensitive to the wrong cleaning agents. Therefore, my question is: Are there any specific cleaners recommended by Ikea or that have proven effective for cleaning Brimnes surfaces gently and efficiently? I would especially like to know which ingredients to avoid, whether all-purpose cleaners are suitable, or if certain products should be avoided. Thanks for your tips and experiences!
As a supplement: The surface of the Brimnes furniture mainly consists of coated particleboard. Therefore, it is essential to avoid solvent-based cleaners, aggressive chemicals, or abrasive agents, as they can damage the coating. Neutral cleaning agents (pH-neutral to slightly alkaline) or mild dish soap diluted in water are ideal. To my knowledge, special "Ikea Brimnes cleaners" are not commercially available. It is also important not to use a wet cloth for extended periods to minimize moisture exposure.
I would like to point out that you should be careful with furniture like Brimnes, as the surface can be sensitive to alcohol-based cleaners or harsh substances. I personally use a simple mixture of warm water and a little mild dish soap. It is important to use a well-wrung cloth so that no moisture can penetrate the edges.
I agree with this; I have also not seen or used any special cleaners from Ikea. If you want to be extra cautious, you can test a small, hidden area before cleaning.
MOMIRA schrieb:
Ikea usually recommends mild soapy water and a soft cloth for Brimnes. Avoid harsh cleaners or abrasive products. I am not aware of any special cleaners from Ikea.
In addition to the points mentioned earlier, I would like to highlight that synthetic sponges or stiff brushes should not be used on Brimnes furniture, as they can scratch the surface.
Cleaning should preferably be done with soft microfiber cloths. For long-lasting care, there are special furniture care products designed for melamine resin coatings, but these are not strictly necessary. A gentle cleaner is usually sufficient.
In summary:
- Use only mild, neutral cleaners
- Avoid alcohol- or solvent-based products
- Use soft cloths or sponges
- Do not use abrasive cleaners
However, no specific Ikea products for Brimnes are listed or offered.
In summary:
