ᐅ Are spare parts available for the Ikea Brimnes furniture that are commonly needed?
Created on: 20 Jan 2020 09:23
kanere
kanere
20 Jan 2020 09:23
Good morning everyone,
I have a question that might seem a bit unusual at first, but I believe it’s relevant for many users of Ikea furniture: Are there spare parts for the Ikea Brimnes furniture system that are commonly needed and easy to purchase?
I’m not only referring to basic mechanical parts like screws or handles, but also specific components such as hinges, drawer runners, or possibly even the back panels. For example, I’ve noticed that the drawer runners on my Brimnes dresser wear out quite quickly, and I’d like to know if Ikea offers replacement parts for such wear items directly, or if you have to rely on third-party suppliers.
Maybe there are also parts that are particularly vulnerable, where it makes sense to proactively keep spares on hand? I’m looking forward to your experiences and advice!
PECLARISSA
20 Jan 2020 10:17
Hello kanere,
great question, I also find it very practical to know where to quickly get replacement parts – no piece of furniture likes to look like it’s been through a lot. 😄
About Brimnes: Yes, especially the drawer slides and handles tend to wear out. My tip: The drawer slides (usually metal rails) are available directly from Ikea as replacement parts. They are quite durable, but if they become stiff or stick, it’s worth replacing them. Handles can also be reordered if they break or get damaged.
Another thing I have noticed: The back panels made of thin particleboard are quite fragile and can crack if the furniture is moved too often or handled improperly. Replacement parts are also available through Ikea’s parts service, if you happen to find one in stock.
My secret tip: Always take good care of the slides during assembly and transport — it saves a lot of hassle! 😉
LANICOLE
20 Jan 2020 11:45
Hi kanere,
I would like to briefly and clearly summarize which spare parts are typically available for the Brimnes system and what to keep in mind:
- Drawer slides/tracks: Usually metal guides that can jam or break over time.
- Handles: For Brimnes, these are often made of plastic or metal and may sometimes be damaged or loose.
- Door hinges: Can wear out or bend.
- Back panel: Thin particleboard that is easily damaged.
Tip 1: Ikea officially offers these spare parts through their customer service and assembly department. It’s a good idea to check using the item number, which is often found on the assembly instructions or on the furniture itself.
Tip 2: When purchasing replacements, always verify whether model numbers have changed, as Ikea frequently updates their products.
If the original parts are not available, you can look for suitable third-party alternatives. This is especially common for drawer slides, though it can be more challenging to find replacements for doors or back panels.
I hope this helps!
Far34
20 Jan 2020 13:02
Brief and to the point:
The drawer slides are the most commonly worn replacement parts for Brimnes.
Handles and back panels are also available but are less frequently damaged.
Replacement parts can usually be found directly through Ikea, or otherwise from third-party suppliers for items like rails.
anno58
21 Jan 2020 08:36
Good morning,
I would like to add to the points mentioned so far, as I have assembled and maintained several Brimnes furniture units.
An important note: When it comes to replacement parts, it is useful to have the exact product name, the serial number, or at least the purchase date ready when contacting Ikea, as their service requires this information to order parts. The availability of replacement parts for Brimnes at Ikea is generally good, but it depends on the specific model.
The following replacement parts are often relevant:
- Drawer slides (made of metal and subject to wear due to weight and frequent pulling out)
- Plastic stoppers or small furniture connectors, which are often misplaced or damaged during moves
- Handles, especially plastic ones that can break
A tip: Panels such as backboards can also be replaced by yourself with comparable materials if Ikea no longer supplies them. In doing so, pay attention to thickness and weight to avoid compromising stability.
In general, I recommend that if a part is no longer in stock, be sure to ask about alternative solutions – sometimes Ikea suggests suitable replacement parts from other product lines.
I hope this helps!
raquel52
21 Jan 2020 15:14
anno58 schrieb:
The following spare parts are often relevant:
- Drawer slides (made of metal and subject to wear from weight and frequent pulling out)
- Plastic stoppers or small furniture connectors, which are often lost or damaged during moves
- Handles, especially plastic ones that can break easily
This summary perfectly matches my knowledge. Additionally, it should be mentioned that the installation of drawer slides often requires special screws or clips, which should also be listed separately as spare parts in case of damage.
Availability at Ikea is generally good, but it depends on current stock levels, so older models can sometimes be difficult to obtain. Therefore, ordering replacements early is advisable.
I would like to emphasize that high-quality spare parts are essential to ensure the long-term functionality of the furniture.
