ᐅ Are there any solutions for converting IKEA BESTA units into pet enclosures or hideouts?
Created on: 5 Apr 2021 14:03
gapraHello everyone,
I am currently considering the idea of converting the IKEA Besta shelving unit into a pet hideaway. My main focus is on practical solutions to modify the unit so that it can serve as a safe and cozy retreat for both cats and small dogs or other small pets.
It is important to me that the conversion remains as stable as possible and that the openings are easily accessible while still feeling comfortable. I am also interested in how to adapt the interior, for example with cushions or insulating materials, and what structural changes to the cabinet might be necessary.
Has anyone had experience or tips on how to cleverly modify the Besta furniture piece to make it pet-friendly? Are there any material recommendations or modular guides?
I look forward to your ideas!
A modification of the IKEA Besta system into a pet cave can be done functionally by considering the following points:
- Remove front or side panels to create suitable access holes that fit the pet.
- Use soft but durable interior padding made from washable materials to ensure hygiene and comfort.
- Stability is maintained if load-bearing elements are not altered, as Besta shelves are modular.
- Optionally, a thin insulation mat can be used inside for thermal insulation, especially in cold rooms.
Additionally, sharp edges should be avoided to prevent injury to pets. Incorporating scratch-resistant fabric or felt can be helpful in this regard.
Roberta schrieb:
You can remove doors or side panels and replace them with fine fabric. Thanks, that sounds practical. What are the exact dimensions of the opening? You mentioned 20x20 cm (8x8 inches); is that sufficient for cats of different sizes?
gadalu schrieb:
Optionally, a thin insulation mat can be used inside as thermal insulation, especially in cold rooms. I find that interesting. Has anyone had experience with these mats? How durable are they when a cat or a small dog lies on them?
Regarding stability: Are there specific limitations when removing individual parts? For example, you can’t just remove an entire side panel, can you?
The 20x20 cm (8x8 inches) opening is sufficient for average house cats, but larger openings can be useful for dogs or cautious cats.
The Besta system is designed so that removing the front and back panels is usually unproblematic, as long as the side frames remain in place. The side walls provide more stability, so at least one side should be kept intact.
Insulation mats or thin foam inserts are designed to withstand the wear from pets; however, they should be securely fixed to prevent slipping. An additional layer of a wipeable cover fabric increases durability and hygiene.
I find this topic very interesting because many of my acquaintances are planning similar projects. It seems important to me to design the construction in a way that the animal truly feels comfortable while preserving the furniture's character.
I notice that the perspective is often missing on how to make the space suitable for the pet: for example, with a soft, easily removable cushion, sufficient airflow, and an appropriate size so the animal can turn around.
Perhaps adding a flap or curtain could create a greater sense of security. I once combined this with a cat tunnel attached to a shelving unit. This provided the animal with several retreat options.
