ᐅ Are there retrofit soft-close kits available for IKEA Brimnes furniture?
Created on: 18 Nov 2018 08:23
Liasnau
Liasnau
18 Nov 2018 08:23
Good morning everyone,
I am currently working on upgrading my IKEA Brimnes wardrobe and am particularly interested in soft-close retrofit kits, as I value the gentle and quiet closing of the doors. My specific question is: Are there suitable soft-close retrofit kits for the IKEA Brimnes series, especially for the wardrobe doors, that can be easily installed without having to completely replace the original fittings? I am mainly concerned with compatibility with the existing materials and simple installation, without needing major modifications to the wardrobe.
Does anyone have experience with this or can recommend appropriate retrofit kits? Perhaps there are even user experiences with certain products or brands that have proven durable. Thanks in advance for any advice!
Mekau
18 Nov 2018 08:59
Yes, there are soft-close retrofit kits compatible with IKEA Brimnes. For example, you can use BLUMOTION dampers or similar brand adapters. The important thing is that the hinges have the appropriate mounting points for these accessories.
Johnathon
18 Nov 2018 12:17
That is basically correct, but I would like to go into more detail to better assess the feasibility for Brimnes users.
The Brimnes series mostly uses standard furniture hinges, which do not have an integrated soft-close mechanism. When choosing a retrofit kit, it is important to consider the following factors:
- Type of hinge: Whether the existing hinge has mounting points for dampers or clips.
- Thickness of the inside of the door: Sometimes too thin material makes it difficult to install external dampers.
- Attachment method: Some retrofit kits require screws, others are clipped on – it is important to check beforehand if the Brimnes material allows this.
A few popular retrofit kits from Blum or Hettich are often recommended in forums; however, they are mainly designed for kitchen furniture. Adapting them to bedroom furniture may vary.
I would also recommend carefully checking before purchasing the dampers whether the depth and angle are compatible with the Brimnes doors, as otherwise functional issues may occur. If anyone has already tested this in practice, a report of experience would be very helpful.
Mariah
19 Nov 2018 09:44
Johnathon schrieb:
I would also recommend checking carefully before buying the dampers whether the depth and angle match the Brimnes doors
I completely agree! 😊
About a year ago, I tried these soft-close retrofit kits myself, and they really made a difference – no more loud slamming! However, I had to adjust the angle of the dampers a bit to make everything fit. It’s important not to use too much force, as Brimnes materials are not as solid as those in kitchen cabinets.
Also, if you’re handy, you can often adjust the positioning of the dampers, but as far as I know, there isn’t a completely simple plug-and-play retrofit kit available for Brimnes.
So, I would recommend opting for a flexible system and maybe visiting a hardware store to explore different options. Good luck with the retrofit!
devon9
20 Nov 2018 14:36
Liasnau schrieb:
Are there suitable soft-close retrofit kits for the IKEA Brimnes series, especially for the cabinet doors, that can be easily installed without completely replacing the original fittings?
To answer this question precisely, here is a structured overview:
1. Compatibility: The hinges of the Brimnes series are usually overlay hinges, which means standard soft-close dampers from brands like Blum or Hettich often fit if they are designed for overlay hinges.
2. Installation: You need either dampers that can be attached directly to the hinges (typically using small clip mechanisms) or dampers mounted separately next to the hinges, secured with a small metal plate.
3. Practical tips:
- Check the thickness and material of the door edge, as some dampers require a lot of space.
- When choosing retrofit kits, make sure they not only provide soft-close functionality but also self-closing action—these two features are sometimes confused.
4. Avoid common mistakes by using a level before installation to ensure the doors hang straight and that the contact surfaces have the correct clearances all around.
Summary: Soft-close retrofit kits for IKEA Brimnes are available but require some adjustment. A completely tool-free upgrade is unlikely; you will need some DIY skills and accurate measurements. Hope this helps.
TYRELL
21 Nov 2018 19:08
Mekau schrieb:
Yes, there are soft-close retrofit kits that are compatible with IKEA Brimnes.
I generally agree with this, but I want to point out some important details that should not be underestimated if you want a truly functional soft-close system.
- The quality of retrofit kits varies greatly. Cheap dampers often do not work reliably or do not slow down enough, so the effect is hardly noticeable.
- Depending on the Brimnes door model, there can be slight differences in mounting height or hinge positioning that affect retrofit compatibility.
- For a durable solution, I recommend dampening hinges with integrated soft-close mechanisms. Although the retrofit kit is cheaper, it often requires more patience and fine-tuning.
A question for the original poster: Do you use Brimnes mainly with shelves or rather the dressers/attachable units? Depending on the load, the lifespan of the retrofit may vary.
