ᐅ Are there any simple repair tips for Ikea BESTA melamine surfaces?
Created on: 7 Jul 2020 08:27
WayanpuHello everyone,
I have a question regarding the care and minor repairs of Ikea Besta furniture with melamine surfaces. Specifically, I’m looking for simple and straightforward repair tips for light scratches, small chips, or dull spots that can occur with everyday use.
How can these surfaces be visually improved with minimal effort, without having to resort to expensive professional products or replacing the entire surface? Are there any home remedies or special tools that work particularly well for this?
Perhaps someone already has experience or proven methods that I could try. I’m looking forward to your tips and advice!
Melamine surfaces are generally quite scratch-resistant but not invulnerable. For minor scratches, the following methods are suitable:
- Cleaning with a mild dish soap and a microfiber cloth to prepare the surface
- For small scratches, special melamine repair kits available at hardware stores often containing heat-activated waxes can help
- Alternatively, careful touch-ups can be done using a white pencil (plastic pencil) or a matching paint pen
It is important not to rub the surface too hard to avoid further damaging the finish.
There is no real DIY solution for matte areas or small chips; usually, the affected section needs to be replaced.
Good sandpaper should not be used on these surfaces, as melamine quickly becomes dull through sanding.
In summary: For most minor damages, repair wax or paint pens are the easiest solutions.
jaanda schrieb:
For small scratches, special repair kits for melamine, often available at hardware stores, usually with heat-activated waxes, can helpI can confirm that. I have also had good experiences with these repair waxes, especially when they are well matched to the color of the surface. It is important to follow the instructions carefully and to clean the area thoroughly beforehand.
One more tip: For very fine scratches, you can also try furniture polish designed specifically for coated surfaces. This often hides minor damage and restores shine.
Unfortunately, larger damages or chips are more difficult to fix. Sometimes sealing the surface with a thin layer of clear lacquer helps, but this is more of a temporary solution.
If you have the serial number or model of the BESTA parts, you can often order replacement parts or panels from IKEA, which is usually the best long-term solution.
Wayanpu schrieb:
How can these surfaces be visually improved without much effort, without having to resort immediately to expensive professional products or replacing the entire surface? Are there home remedies or special tools that work particularly well for this?I once tried a small trick that really surprised me: For light surface scratches, I simply used a knife or a fingernail to gently rub along the scratches – important, very gently! Then I applied a regular furniture polish. This already improved the appearance significantly for me, without any expensive repair kits.
Another simple tip is to lightly wipe over matte spots and minor signs of wear with a polishing cloth used for cars – sometimes that restores the shine.
Of course, this sounds a bit like a "home remedy toolkit" and it’s not perfect for every situation. But if you work with some care, you can often disguise minor damage quite effectively.
Raymond schrieb:
For very fine scratches, you can also try furniture polish that is specially designed for coated surfaces.I can fully agree with that. I find it very reassuring when simple solutions like furniture polish already yield good results, especially since not everyone feels comfortable using repair kits.
Besides, it just feels better to me not to switch immediately to large-scale replacements when small scratches or wear appear.
However, you should be careful when choosing the polish to avoid unwanted residues or discoloration. Always test on an inconspicuous area first!
I’m curious to see if any more tips will be shared here. The small flaws in our furniture often surprise me, but the idea of replacing them right away doesn’t make me happy.
