ᐅ Are there any safety measures for IKEA PLATSA furniture in family homes?
Created on: 4 Nov 2018 09:37
Parbau40
Parbau40
4 Nov 2018 09:37
A few weeks ago, I started using IKEA Platsa furniture in my family home, mainly because of its flexible assembly options and modern design. However, I am now wondering if there are any specific safety precautions to consider with this furniture to prevent accidents in daily life, especially with children around.
I am interested in practical advice on how to stabilize the furniture, child-friendly assembly methods, and whether IKEA has issued any special safety mechanisms or recommendations for Platsa that go beyond the usual wall fastenings.
Are there safety measures for IKEA Platsa furniture in family homes to reduce risks from tipping or loosening? I look forward to your experiences and tips!
Ianlau
4 Nov 2018 09:52
Hello Parbau40,
Your question is very important, as taller furniture pieces can pose a real safety risk, especially with children. Regarding IKEA PLATSA, I can say that IKEA usually includes wall fasteners, which are mandatory for this system as well. The most important thing is to securely anchor the furniture to the wall to prevent tipping.
Additionally, I recommend:
- Following the assembly instructions carefully, especially tightening all screws and connectors properly.
- Ensuring children do not have access to climb on the furniture or use it as a climbing frame.
- If possible, using extra stabilizers, such as additional brackets or connecting hardware from a hardware store.
IKEA explicitly states in the PLATSA instructions that wall mounting is required. Heavy items should not be stored on the top shelves. Safety must always come first.
gla-tan
4 Nov 2018 10:07
The wall fasteners from IKEA for PLATSA are mandatory.
Additionally, the furniture should not be overloaded, and children should be clearly instructed that it is not a climbing aid. That's it.
V
valerie-tr
4 Nov 2018 11:34
I would like to add some technical details and additional safety considerations regarding the use of IKEA PLATSA furniture in family homes:
Platsa furniture is modular, offering a wide range of configuration options. However, this flexibility also carries risks if individual modules or tops are not properly connected or secured.
Important points:
- Wall mounting is not just recommended but mandatory. IKEA provides different mounting systems depending on the wall type (e.g., anchors for concrete, cavity wall anchors for drywall).
- The plug and screw connections between modules must be securely fastened using the provided hardware.
- Extra caution should be taken with sharp edges around children. Although most of the furniture features rounded edges, it is still advisable to apply soft edge or corner protectors.
- It is also possible to equip internal compartments with safety locks if you want to keep food supplies or small items out of children’s reach.
Important for you: What does your current setup look like? Are the furniture pieces fully assembled, or are you still building them? This will affect what specific safety tips I can provide.
Parbau40
4 Nov 2018 11:46
valerie-tr schrieb:
What does your current setup look like? Are the furniture pieces fully assembled, or are you still putting them together? That would affect the specific advice I can give you regarding securing them.
Thank you for the detailed response. My setup is currently at a stage where several individual combined units are already in place, but not yet all connected to each other. The modules are sometimes just stacked on top of each other—before wall mounting and final securing. I have two small children (2 and 5 years old), so stability is really very important to me. The furniture is located near play areas and will likely be used as climbing aids if the child is allowed.
If I understand correctly, connecting the units to each other is at least as important as attaching them to the wall? Where should one start if, for example, a wall cannot be fully used? Are there alternative securing options or accessories that can be used?
Maybe someone else has practical experience with tips and tricks to share.
O
olivernu
4 Nov 2018 12:21
Parbau40 schrieb:
The furniture is located near play areas and is likely sometimes used as climbing aids
This is an important point. The safest approach is indeed to directly anchor all modules to the wall, as this provides the greatest stability.
If wall mounting is not possible in some places, for example due to regulatory restrictions in rental apartments or drywall without suitable fixing options, I recommend:
- Installing base feet or angle brackets on the bottom furniture unit to reduce forward tipping.
- Ensuring very stable connections between the modules. Additional screws from a hardware store can be used if the manufacturer’s connections are insufficient.
- Avoid placing heavy loads on the upper shelves whenever possible.
In general: children should not be left unattended near such furniture, as there are risks even with well-secured units.
