ᐅ Are there any risks associated with using IKEA Hemnes furniture for heavy loads?
Created on: 24 Sep 2023 10:23
Plotar
Hello everyone, I recently started looking at the Hemnes series furniture from IKEA, especially dressers and cabinets, because I want to store some heavier items in them – for example, toolboxes, thick books, and sometimes boxes with electronic devices. My question is: Are there any risks when using IKEA Hemnes for heavy loads?
I have already seen in the product descriptions that there is a recommended maximum load per shelf, but I would like to hear from your experience whether the build quality and construction are really as sturdy as they seem. Could the drawers or the frame be damaged or start to bend over time?
I would also be interested in advice on whether it is better to anchor the furniture to the wall, or if that is not really necessary. I just want to avoid doing something wrong and having something break sooner than expected. Thanks for your insights.
Tobias
25 Sep 2023 08:07
It is important not to overload the drawers, as they are not designed for very heavy loads.
Wall mounting prevents tipping.
Do not concentrate heavy loads on shelf boards.
Luciandi
25 Sep 2023 10:29
Deandre schrieb:
Wall anchoring is always advisable, especially when the piece of furniture is tall and heavily loaded, as it improves stability and prevents it from wobbling or tipping over.
I also find this very important. Especially if you have children or pets at home, such a piece of furniture can quickly become a hazard if it is not secured.
It also gives you peace of mind knowing that not only does the furniture stand more securely, but that I can store things more safely.
I have a similar Hemnes furniture piece in use and always make sure not only to distribute the load, but also to properly screw it to the wall.
neoren
26 Sep 2023 09:18
For heavy loads: pay attention to floor load capacity and do not exceed it.
Drawers should be used mainly for light items.
Wall mounting is mandatory.
Deandre
26 Sep 2023 11:02
Plotar schrieb:
I just want to avoid doing something wrong and having something break faster than expected.
That’s a good approach! Keep in mind that furniture like Hemnes is well-made but falls within the mid-price range. It’s not designed for industrial-level loads. So, if you plan to regularly store very heavy items (more than 20 kg per shelf), you should either distribute the weight evenly or consider furniture with a higher load capacity.
If you only store heavy items occasionally, it’s less critical as long as you secure the furniture to the wall and distribute the weight properly.
Feel free to stay in touch and write if you have more details about the intended use—I’m happy to help!
